CODESYS RPI2 and serial communication
Damian7546
2017-12-08
2017-12-10
  • Damian7546 - 2017-12-08
    I have a problem with serial communication.
    My CODESYSControl.cfg file is:
    [SysCom]
    Linux.Devicefile=/dev/ttyAMA
    portnum := COM.SysCom.SYS_COMPORT1;
    Linux.Devicefile=/dev/ttyACM
    portnum := COM.SysCom.SYS_COMPORT2;
    On port 1 everythink is ok. It is work, but I have problem with port2.
    I can't even open this port.
    Example on screenshot in attachment.
    Where is the problem ?
    IMG: zdj1.jpg
  • eschwellinger
    eschwellinger - 2017-12-08
    this does not work that way.
    use only this
    [SysCom]Linux.Devicefile=/dev/ttyAMA
    and set a symlink in Linux for
    /dev/ttyACM0 -> =/dev/ttyAMA1
  • Damian7546 - 2017-12-09
    I used command:
    sudo ln -s devttyACM0 devttyAMA1
    and it is works, but after reboot AMA1 disapear, what is wrong ?
  • eschwellinger
    eschwellinger - 2017-12-10
    guess the proper solution is to add it by udev rules
    would recommen to google for it.
    If you add a symbloc link sure you need to add after rebooting the system..
