RPi 3 as Profinet Master with Profinet Device
rKtiC
2017-12-04
2019-03-27
  • rKtiC - 2017-12-04
    Hi everyone,
    I have a problem using the RPi 3 Model B as a Profinet Master in Codesys.
    My system is as follows:
    I have a computer running Windows 7 with CoDeSys v. 3.5 SP11 to program the PLC. The computer is connected via a switch a raspberry pi 3 Model B and a profinet device. I installed the profinet device with a GSDML-file. The device is a SCHUNK EGL90 PN.
    In CoDeSys I can find the RPi3. I added an Ethernet device and below this a profinet controler (with the IP of the RPi3) and below that the profinet device.
    When I log in everything seems to work but I do not get any values (see screenshots CoDeSys_1 & CoDeSys_2).
    Does anyone have an idea why? Do I have to switch lowbyte and highbyte and if yes, how do I do this?
    I would be very grateful to get any tip!
    rKtiC
    IMG: Bild
    IMG: CoDeSys_2.png
    IMG: CoDeSys_1.png
    eschwellinger - 2017-12-04
    everything seems ok,
    you just need to map varibales.. then the process varibales should work.
    (No mapping no processdata exchange)
    IMG: AlwaysUpdate.jpg
  • rKtiC - 2017-12-07
    Thank you for your answer Edwin.
    Mapping the variables wasn't a problem but now it seems that I get values for only some of the BOOL-variables. The other ones are greyed out (screenshot ‘CoDeSys_3’).
    Sometimes I got also values for other REAL-variables but then they disappeared again.
    As you can see in screenshot ‘CoDeSys_4’ it looks like that port-001 of the PN-controller is not active. Could that be a reason? If yes, how can I activate it?
    rKtic
    IMG: CoDeSys_3.png
    IMG: CoDeSys_4.png
    eschwellinger - 2017-12-08
    yes for me it is clear why.
    IMG: mapping.jpg
    or use option 2:
    update always Setting.
    IMG: Enable2.jpg
  • rKtiC - 2018-01-02
    Happy New Year!
    Everything works now. The two bytes of status and control word have to be swapped.
    Thanks for the help!
  • grunf - 2018-07-24
    Well, dont know what i did wrong. When i scan for device i can see my Kuka robot and ip adress that i set on KRC, but got this error?
    IMG: viber image.jpg
    eschwellinger - 2018-07-25
    which error do you mean - there is no error - next step is to select the line in this scan dialog and exceute
    'Set Name + IP'.
    -> then 'copy all devices to project' - and do a new download
    IMG: SetIPandName.png
  • grunf - 2018-07-25
    thx Edwin, think i try that, but nothings happend? Will try again today, and post results!
    BG
    me again, now thats the error, but ip adress in krc is set to valid range
    IMG: Untitled.png
    wow stupid mistake, i solved my issue ......connected all eth interfaces on unmenaged switch, nad everythings works at glance
    eschwellinger - 2018-07-27
    Important Information for PI3B plus and current Raspbian:
    If someone is using PI3B+ with Profinet Controller / Device on eth0.
    There is a known issue with current Raspian and new Ethernet Driver:
    the following steps are needed:
    sudo apt install vlan   # VLAN-Paket installierensudo modprobe 8021q     # 8021q Kernelmodul laden
    loading the kernel module could be done on restart by:
    sudo su -c 'echo "8021q" >> /etc/modules'
  • Snoopy354 - 2019-03-27
    Hello Edwin,
    Is this already fixed?
    Bruno
    eschwellinger - 2019-03-27
    hm.. guess not,
    this need to be added to the RASBIAN Image by Rasbian.org
