I have several RPi using Codesys with licence and I could see that my device reboot after 2h.
My device has an external watchdog that reboots the RPi if the PLC shut down.
With a little bash script I logged the status of codesyscontrol service every second until RPi reboot, and my last entry before the reboot is each time 2h and 5min after codesyscontrol start running.
I tried without an external watchdog and the service is exited instead of running, logs below :
β codesyscontrol.service - LSB: Prepares and starts codesyscrontol
Loaded: loaded (/etc/init.d/codesyscontrol)
Active: active (running) since Sat 2017-10-28 08:17:06 UTC; 2h 5min ago
Process: 510 ExecStart=/etc/init.d/codesyscontrol start (code=exited, status=0/SUCCESS)
CGroup: /system.slice/codesyscontrol.service
ββ650 /usr/bin/codesyscontrol.bin
ββ656 /usr/bin/codesyscontrol.bin
Active: active (exited) since Sat 2017-10-28 08:17:06 UTC; 2h 5min ago
I though it was codesyscontrol without licence rebooting every 2h.
Is there something special to do at the licence installation? I followed the same steps as this youtube video : /watch?v=eTr9oO9OAy8
Screenshot of API Param below :
Information :
- Raspberry Pi 3, Model B, 1GB RAM
- Raspbian (v4.9.46-v7+)
- CODESYS Control for Raspberry Pi SL (V3.5.10.0)
- SD are installed by binary copies of another one
BR,
Vincent
-SD are installed by binary copies of another one
If you copy a licensed CODESYS sd Card,
the steps are to activate the "new" license
-> remove the content of cmact_license
-> restart plc
-> activte the new license
If you do not follow these steps- you'll have a broken license conatiner from the original Pi
sure you could activate a license to the new empty Container - but the license from first Pi stay there and will influcense
the license requests in that way.
Information :
BR,
Vincent
-> restart plc
Okay, I tried what you said and that was the issue.
Everything works fine now.
Big thanks Edwin!
Vincent
