Hello, im running codesys V3.5 on a raspberry pi 2.
I add an Ethernet controller, then a Modbus master and then finally a Modbus slave.
My problem is that i cant find where to put the Slave IP adress..
Thnak you for you help
seems to be a localisation problem,
could youtry to switch the CODESYS language to english?
Well done ! It was a language problem.
I switch to English then its prompt the IP adress field.
Thank you very much
