RPI CANBUS
lemaitre
2017-10-13
2017-10-15
  • lemaitre - 2017-10-13
    I have a problem with the rts_set_baud.sh script.
    I don’t understand, the script is at root
    Have you an solution ?
    thks
    David
    IMG: Codesys error.jpg
    IMG: locate script.jpg
    IMG: droit script.jpg
  • eschwellinger
    eschwellinger - 2017-10-13
    I would recommend to check how this is done in beaglebone black
    there the can is supported.
    Ok thanks for your advice.
    But the canbus is no longer supported on the RPI?
  • eschwellinger
    eschwellinger - 2017-10-14
    we just add all needed components to the runtime (obviously without this script)
    As you need anyway to build a customized kernel with included socketcan (or is this nowadays not needed anymore?)
    At that time we decide just add the license for the users which manage to deal with restricitions.
  • lemaitre - 2017-10-14
    I think i don't need a specfic kernel.
    My application requires just CANBUS with sofmotion light for 3 axis.
    My can RPI canboard is avaible but codesys script is disable.
  • lemaitre - 2017-10-15
    I have find a solution to done the canBus.
    I use a RaspiLC Iso:
    Raspbian Jessie-Desktop Kernel 4.9 Codesys-Runtime 3.5.11
    But now i have this: Module not found
    IMG: Driver not found.jpg
