It is currently Wed Jul 18, 2018 8:07 am
PostPosted: Wed Oct 11, 2017 4:55 pm
Good evening,
I have problems reading analog values from an arduin one connected in modbus tcp.
Virtually I can control the status of inputs and outputs but no value comes from analog pins.
I attach the arduino code and the codesys screen.
Where am I wrong?
Thank you, Alberto
#include <SPI.h>
#include <Ethernet.h>
#include "MgsModbus.h"
MgsModbus Mb;
int inByte = 0; // incoming serial byte
// Ethernet settings (depending on MAC and Local network)
byte mac[] = {0x90, 0xA2, 0xDA, 0x0E, 0x94, 0xB6 };
IPAddress ip(10, 0, 0, 46);  // Unwrapper   192, 168, 0, 5
IPAddress gateway(10, 0, 0, 1);
IPAddress subnet(255, 255, 255, 0);
//Configuration Digital IN
int IN1 = 2;
int IN2 = 3;
int IN3 = 5;
int IN4 = 6;
//Configuration Digital OUT
int OU1 = 7;
int OU2 = 8;
int OU3 = 9;
//Configuration Analog IN
int AN0 = A0;
int AN1 = A1;
int AN2 = A2;
int AN3 = A3;
int AN4 = A4;
int AN5 = A5;
void setup()
  io_setup(); // I/O settings
  // serial setup
  Serial.begin(9600);
  Serial.println("Serial interface started");
  // initialize the ethernet device
  Ethernet.begin(mac, ip, gateway, subnet);   // start etehrnet interface
  Serial.println("Ethernet interface started");
  // print your local IP address:
  Serial.print("My IP address: ");
  for (byte thisByte = 0; thisByte < 4; thisByte++) {
    // print the value of each byte of the IP address:
    Serial.print(Ethernet.localIP()[thisByte], DEC);
    Serial.print(".");
  Serial.println();
void loop()
  io_poll(); // I/O settings
  unsigned int j;
  //In monitor seriale inserire 10 per vedere lo stato dei bit
  if (Serial.available() > 0) {
    // get incoming byte:
    inByte = Serial.read();
    if (inByte == '0') {         // print MbData
     int i = 0;
     int j = 0;
     Serial.println();
      for (i=0;i<5;i++) { //Number of channel
        Serial.print("Mb.MbData["); Serial.print(i); Serial.print("]="); Serial.print(Mb.MbData[i]);
        Serial.print(" BIN: ");
        for ( j=0;j<16;j++) { // Number of bit
              Serial.print(bitRead(Mb.MbData[i], j));
         Serial.println();
       Serial.println();
  Mb.MbsRun();
void io_poll() {
//INPUT DIGITAL
    bitWrite(Mb.MbData[0], 0 , digitalRead(IN1));
    bitWrite(Mb.MbData[0], 1 , digitalRead(IN2));
    bitWrite(Mb.MbData[0], 2 , digitalRead(IN3));
    bitWrite(Mb.MbData[0], 3 , digitalRead(IN4));
//OUTPUT DIGITAL
    digitalWrite(OU1, bitRead(Mb.MbData[1], 0));
    digitalWrite(OU2, bitRead(Mb.MbData[1], 1));
    digitalWrite(OU3, bitRead(Mb.MbData[1], 2));
//INPUT ANALOG
    Serial.println (Mb.MbData[2]);
    bitWrite(Mb.MbData[2], 0 , analogRead(AN0 * 0.48875));
    bitWrite(Mb.MbData[2], 1 , analogRead(AN1));
    bitWrite(Mb.MbData[2], 2 , analogRead(AN2));
    bitWrite(Mb.MbData[2], 3 , analogRead(AN3));
    bitWrite(Mb.MbData[2], 4 , analogRead(AN4));
    bitWrite(Mb.MbData[2], 5 , analogRead(AN5));
void io_setup() {
  pinMode(OU1, OUTPUT);
  pinMode(OU2, OUTPUT);
  pinMode(OU3, OUTPUT);
  pinMode(IN1, INPUT);
  pinMode(IN2, INPUT);
  pinMode(IN3, INPUT);
  pinMode(IN4, INPUT);
  pinMode(AN0, INPUT);
  pinMode(AN1, INPUT);
  pinMode(AN2, INPUT);
  pinMode(AN3, INPUT);
  pinMode(AN4, INPUT);
  pinMode(AN5, INPUT);
PostPosted: Sat Oct 14, 2017 9:23 am
Nothing help ?
PostPosted: Wed Oct 18, 2017 12:33 pm
Good morning,
I did a simple program to figure out how to read an analog value from an arduino one connected to modbus tcp.
Using a test program (jbus) to see the values that pass on the bus I can see the value sent but in codesys i do not see other than 0.
Can you help me understand what's wrong?
Thank you, Alberto
PostPosted: Fri Oct 20, 2017 7:59 pm
Solved :D
