Bit not enabled in modbus tcp read
alverman
2017-10-08
2017-10-09
  • alverman - 2017-10-08
    Good evening,
    do you think bit5 is not active?
    What can be caused?
    Thank you, Alberto
    IMG: D1.png
  • Anonymous - 2017-10-09
    Do you use the variable linked to bit 5 anywhere in your code? I have seen the compiler "compile out" the update over bus systems when the variable I have mapped is not used at all. You need to at least just have a line in PLC_PRG with your variable and a semicolon.
  • teichhei - 2017-10-09
    Agreed, I'd say you are not using the variable in the application.
    Sent from my SM-G935F using Tapatalk
  • alverman - 2017-10-09
    Is true !!
