Running slow
Kjaerre
2017-09-27
2017-09-28
  • Kjaerre - 2017-09-27
    Hello.
    I have a problem with my raspberry, if i do not have the onewire connected, all other gpio activates and deactivates fine through the codesys program i made, but once i insert a onewire temperature sensor, i takes 5-10 seconds to react
    if i connect the temperatur sensor, it displays the temperatur and adress of the sensor fine
    any thoughts?
    eschwellinger - 2017-09-28
    you need to use the onewire devicesin an own task.
    See attched example application.
    IMG: OneWireTask.jpg
    Onewire_twoTasks.project [75.67 KiB]
