Hi Steve,
I have tried to reproduce this,
does work in my case....
Everything in newest Version?
Guess you need to attch the project.
Ah now I got it:
You are running CODESYS 64Bit and simulation is active...right?
There is already an entry in our bug tracker system.
Workaround: Use the Control Win (running on the same PC than CODESYS / not Simulation mode)
I am new to CODESYS and I am trying to use EtherNet/IP.
I made a small test application and get 2 errors during compiling :
C0288: Cannot access private Method Assembly.GetParamNBitOffset
How can I solve this issue ?
Thanks in advance.
Best regards,
Steve
Hi Steve,
Ah now I got it:
Hello Edwin,
In fact, I am running CODESYS on a 64bit machine but "Simulation" seems to be inactive.
What do you mean by "Use the Control Win" ?
Regards,
Steve
see attached Picture,
-start the local plc
-updat you project by rightclick to this plc
-login to this plc
If this is not a simulation (it looks different) problem you need to attach the project to check.
It is not excluded that I am on the wrong way.
Here is my simple test project.
Regards,
Steve
GPIO_170915.project [336.17 KiB]
please update the scanner and Ethernet connector to current Version (SP11)Β΄,
by rightclick and 'update' device.
I finally complete my test project with CODESYS on Raspberry Pi and I work great.
Many thanks for your help.
Next step : Buy a license.
Regards,
Steve
Hello Steve,
I am also facing same problem. Could you please guide how do you have resolved these errors??
Thanking you in advance.
Regards
Arjun
