Raspberry Pi & EtherNet/IP (CIP) [Solved]
smuller
2017-09-19
2017-10-18
  • smuller - 2017-09-19
    I am new to CODESYS and I am trying to use EtherNet/IP.
    I made a small test application and get 2 errors during compiling :
    C0288: Cannot access private Method Assembly.GetParamNBitOffset
    How can I solve this issue ?
    Thanks in advance.
    Best regards,
    Steve
  • eschwellinger
    eschwellinger - 2017-09-19
    Hi Steve,
    I have tried to reproduce this,
    does work in my case....
    Everything in newest Version?
    Guess you need to attch the project.
    Ah now I got it:
    You are running CODESYS 64Bit and simulation is active...right?
    There is already an entry in our bug tracker system.
    Workaround: Use the Control Win (running on the same PC than CODESYS / not Simulation mode)
    Hello Edwin,
    In fact, I am running CODESYS on a 64bit machine but "Simulation" seems to be inactive.
    What do you mean by "Use the Control Win" ?
    Regards,
    Steve
    IMG: codesys.jpg
  • eschwellinger
    see attached Picture,
    -start the local plc
    -updat you project by rightclick to this plc
    -login to this plc
    If this is not a simulation (it looks different) problem you need to attach the project to check.
    IMG: Start_Control_Win_plc.jpg
    It is not excluded that I am on the wrong way.
    Here is my simple test project.
    Regards,
    Steve
    GPIO_170915.project [336.17 KiB]
  • eschwellinger
    please update the scanner and Ethernet connector to current Version (SP11)Β΄,
    by rightclick and 'update' device.
    IMG: UpdateDevice.jpg
  • smuller - 2017-10-09
    I finally complete my test project with CODESYS on Raspberry Pi and I work great.
    Many thanks for your help.
    Next step : Buy a license.
    Regards,
    Steve
  • arjun-ele - 2017-10-18
    Hello Steve,
    I am also facing same problem. Could you please guide how do you have resolved these errors??
    Thanking you in advance.
    Regards
    Arjun
