I have converted an array of bytes into a string. Worked like a charm with the oscat function btw.
Now i have to put it into hex-values. Any way to create a string with hex values?
2017-09-08
You can make your own solution by using two offsets. Look at each byte. If it is >=10 then add 55 to it (A is ascii 65). For smaller number, add ascii offset for 0 - sorry don't remember if it is 40 or 42). Examine bytes from highest to lowest and con at your chars.
There is probably a prebuilt function somewhere, but it may take you longer searching for it than building it.
scott_cunningham hat geschrieben:
OK that's great but still facing a major problem for me.
Let's say i got value 58 in one byte. Then i want it displayed as 3A. (Hex is 4 bits). And i don't see any solution in it then
2017-09-11
58 = 0011 1010 in binary. Hex uses four bits (nibble). You have to look at the upper four bits (3), then the lower four bits (A).
A WORD uses two bytes (four nibbles) and can have a number from 0000 to FFFF hex.
A BYTE uses one byte (two nibbles) and can have a number from 00 to FF hex.
Here is a crude function to convert a BYTE to a two char string. It is up to you to expand it for longer variable types...
FUNCTION BYTE_TO_HEX_STRING : STRING
VAR_INPUT
Input : BYTE;
Temp : BYTE;
Chr : BYTE;
Ans : STRING;
VAR_INPUT
Input : BYTE;
Temp : BYTE;
Chr : BYTE;
Ans : STRING;
Temp := SHR(Input, 4);
IF Temp > 9 THEN
Chr := Temp + 55;
ELSE
Chr := Temp + 48;
Ans[0] := Chr;
Temp := SHR(SHL(Input,4),4); //wipes upper nibble (could also mask...)
IF Temp > 9 THEN
Chr := Temp + 55;
ELSE
Chr := Temp + 48;
Ans[1] := Chr;
Ans[2] := 0; //null char
BYTE_TO_HEX_STRING := Ans;
I managed to get it to work for longer variable types. Worked like a charm
Hello NBCC, I work on the same problem as you but I have to work with WORDs and not BYTEs, could you please explain me how did you managed to get it to work for longer variable types ?
I know this is an old post but I still hope that someone will answer...
in fact (this question is more for scott_cunningham) , I don't understand why and what is really done here :
IF Temp > 9 THEN
Chr := Temp + 55;
ELSE
Chr := Temp + 48;
Hi all,
VAR_INPUT
Input : BYTE;
Temp : BYTE;
Chr : BYTE;
Ans : STRING;
IF Temp > 9 THEN
Chr := Temp + 55;
ELSE
Chr := Temp + 48;
Ans[0] := Chr;
IF Temp > 9 THEN
Chr := Temp + 55;
ELSE
Chr := Temp + 48;
Ans[1] := Chr;
IF Temp > 9 THEN
Chr := Temp + 55;
ELSE
Chr := Temp + 48;
Hi kdkwhite,
for Word you still can use suggested code by using a union structure and crack down your Word to two byte as bellow:
then define your variable as this type:
now assign your Word variable input to InWord and send OutBytes[x] to the mentioned method:
Regarding your question about the code: actually 48 is ascii code of "0" and while 65 is the ascii code of "A" so in above code 55 + 10 would be 65.
Last edit: alimans 2023-09-20
