Displaying html files in the Webbrowser element of WebVisu
2017-08-04
2020-12-15
  • johan76swart - 2017-08-04
    Hi All,
    Has any one managed to display html files saved on the raspberry in the Webbrowser element of WebVisu. I know it works with a normal http://www.somepage.com but
    I cant seem to get it to display a locally save html.
    Thanks in advance
    Best Regards
    Johan
  • PAFL - 2019-07-24
    Hi All,
    I know this is an old post, but does anyone found a solution for this.
    IΒ΄m struggling with the same probem.
    Thanks
  • m.prestel - 2019-07-24
    hello everyone,
    this is quite easy.
    You simple provide the url to the html file.
    To get the attached project to work, create a html file (name it "helloworld.html") in your $PlcLogic$/$visu$ folder, download the project and click show.
    Best regards,
    Marcel
    IMG: helloworld.PNG
    Webbrowser.project [141.97 KiB]
  • PAFL - 2019-07-24
    @m.prestel
    You're right!
    It's actually quite simple.
    Thank's a lot!
  • vashellandia - 2020-12-14
    Hello, revive an old usefull topic, basically I'm using a hmi-plc from Turck, rebrand from. Exor. Basically if I use webbrowser widget-tool, when online with engineering I see the page, but on the hmi itself nothing, blank. There is any restiction on the usage of that tool? Must be installed any additional specific library or tool on the hmi? Tha k You very much in advance
  • m.prestel - 2020-12-15
    @vashellandia I think you have to redirect this question to your OEM.
    I haven't used a plc from Turck so I cannot answer the question.
    Best regards,
    Marcel
