Install the Raspberry PI Package by clicking on the shopping cart in CODESYS
Restart CODESYS (to get the 'Update Raspberry Pi' command under Tools) - this is used to deploy the plc runtime to the PI
(ssh need to be eabled on Pi side see: https://www.raspberrypi.org/blog/a-secu ... ian-pixel/)
Now you find all examples and attached pdf documentation here:
"c:\Users\CODESYS Control for Raspberry PI\3.5.\Documentation\RaspberryPI_CodesysV3_FirstSteps_EN.pdf"
i did these steps but don't get the update raspberry.
does the raspberry pi needs to be connected in order to see the ''update raspberry'?
do i need to buy a license first for the raspberry?
i was told it will run for 2 hours without a license?
Peter
I did restart codesys many times, did not help. this is package I installed:
CODESYS Control for Raspberry PI 3.5.15.40.package
is that the correct one?
Peter
Now i can execute the command, codesys finds the raspberry, its a raspberry 4B, brand new.
it does not offer me to download a codesys version to the pi.
any more help?
Peter
seems that you are using CODESYS as user 'e0037505' user,
different as you have been logged in when you have installed the backage.
Is this possible?
Either install it again under this user or copy it from the
"c:\Users\<windowsusername>\CODESYS Control for Raspberry PI\"
to your 'e0037505' user.
This explains the missing command too.</windowsusername>
Last edit: eschwellinger 2020-04-13
thanks, that works. Installations i have to do under a supervisor account, than things like that can happen.
so.
now codesys loaded the runtime on the raspberry pi. i'm connected via wifi. now i try to connect my codesys to the raspberry plc.
somehow the 'gateway' is not setup correctly?
already solved, i had the gateway (which is one piece of software running in the system tray) shut down.
now its running.
by the way, what i really want to do is have the raspberry pi as a master for Profinet in order to test out and develop profinet slaves.
Peter
Is there a step-by-step tutorial for using Raspberry pi 3 with codesys v3.5? What do I have to buy to use the Raspberry with PLC?
see this small description and attached pdf from the package:
Download the CODESYS Development System
https://store.codesys.com/engineering/codesys.html
How to activate the license faq:
l viewtopic.php?f=22&t=5641&p=10688#p10688 l
RaspberryPI_CodesysV3_FirstSteps_EN.pdf [885.7 KiB]
Peter
No, just restart CODESYS, after Install Tagen package from the CODESYS Store..
Peter
this is user rights related .. maybe, Workaround:
You could add the update command manually:
Last edit: eschwellinger 2020-04-11
Great, thanks, that was working.
any more help?
Peter
Is this possible?
so.
one more thing, the message back was:
now its running.
Peter
