It is currently Tue Feb 18, 2020 2:16 am
 Post subject: csv log file
PostPosted: Tue Jun 06, 2017 9:52 pm
I am trying to create a CSV log file. I have a string within my programme that contains a few variables, some sensor data and internal calculations.
Here's my predicament, as the data in my string changes, I need to write the data every time FiWr becomes true. This is happening with the code below, however each time FiWr becomes true and writes the string to the CSV file it overwrites the existing data, so no matter how many times FiWr becomes true I only ever have one line in my CSV file. I would like to see a new line written to the CSV file each time FiWr becomes true.
STR1:= CONCAT(TEMPSTRINGCO, FACSTRINGCO);
STR2:= CONCAT(COUNTSTRINGCO, '$R$N');
FINSTR:= CONCAT(STR1, STR2);
xFileStdInit:= RUN;
IF NOT xFileStdInit THEN
    filop(xExecute:=FALSE);
    filcl(xExecute:=FALSE);
    filwr(xExecute:=FALSE);
    filrd(xExecute:=FALSE);
    xFileStdInit:=TRUE;
    uiFileStdState:=0;
ELSE
    CASE uiFileStdState OF
        0:(* create a new file *)
            filop.sFileName:=sFileName;
            filop.eFileMode:=FILE.MODE.MRDWR;
            filop.xExclusive:=TRUE;
            filop( xExecute:=TRUE);
            IF filop.xDone THEN
                hFile:=filop.hFile;
                uiFileStdState:=1;
            IF filop.xError THEN
                (* error handling*)
        1:(* close file  - TestFile.txt *)
            filcl.hFile:=hFile;
            filcl( xExecute:=TRUE);
            IF filcl.xDone THEN
                uiFileStdState:=2;
            IF filcl.xError THEN
                (* error handling*)
        2:(* end of example *)
    END_CASE
IF NOT  FiWr THEN
   filgp(xExecute:=FALSE);
   filsp(xExecute:=FALSE);
   FiWr:= TRUE;
    csvwrite:=0;
ELSE
    CASE csvwrite OF
            filop.eFileMode:=FILE.MODE.MAPPD;
            IF filop.xDone THEN
                hFile:=filop.hFile;
               csvwrite:=1;
                (* error handling*)
            1:(* get actual internal positon file pointer *)
                 filgp.hFile:= hFile;
               filgp (xExecute:=TRUE);
                filgp.xBusy;
             filgp.xError;
             filgp.eError;
                 IF filgp.xDone  THEN
                 WritePoint:=filgp.udiPos;
                 csvwrite:=2;
            IF filgp.xError THEN
               (* error handling*);
         2:(* set actual internal positon file pointer *)
                 filsp.hFile:= hFile;
             filsp (udiPos:=WritePoint);
               filsp (xExecute:=TRUE);
               filsp.xBusy;
             filsp.xError;
             filsp.eError;
                 IF filsp.xDone  THEN
                 csvwrite:=3;
        3:(* write text in the file *)
            filwr.hFile:=hFile;
            filwr.pBuffer:=ADR(FINSTR);
            szFileSize1:=SIZEOF(FINSTR);
            filwr.szSize:=szFileSize1;
            filwr.udiTimeOut:=100000;    (* 100ms Timeout *)
            filwr( xExecute:=TRUE);
            IF filwr.xDone THEN
                csvwrite:=4;
            IF filwr.xError THEN
                (* error handling*)
        4:(* close file  - TestFile.txt *)
            filcl.hFile:=hFile;
            IF filcl.xDone THEN
                csvwrite:=5;
                (* error handling*)
        5:(* end of example *)
    END_CASE
 Post subject: Re: csv log file
PostPosted: Fri Aug 04, 2017 12:32 pm
Hi Primative Source,
I have used the following code in a function block,
Put these variables in you variable editor:
//This Function block requires SysFile = SysFile, 3.5.6.0 in the Library Manager
FUNCTION_BLOCK TEXT_TO_FILE
VAR_INPUT
   xFilePath: STRING;
   xText_Write: STRING(2000);
   xAppend_OverWrite: BOOL;
   xAppend_Pos: UDINT;
   xWrite: BOOL;
   xRead: BOOL;
   xLine_No_To_Read: UDINT;
VAR_OUTPUT
   xText_Read: STRING(2000);
   xDone: BOOL;
// Write Variables
   xWrite_Trig: R_TRIG;
   xStart_Write: BOOL;
   xNew_Line: STRING(2000);
// Read Variables
   xRead_Trig: R_TRIG;
   xStart_Read: BOOL;
   xLine_Read: UDINT;
   hFile           : RTS_IEC_HANDLE := RTS_INVALID_HANDLE;
   udiBytesRead    : UDINT;
   udiBytesCopied   : UDINT;
   udiWrite      : UDINT;
   udiFileSize     : UDINT;
   udiPos         : UDINT;
//(* Error Codes *)
   udiPosError          : RTS_IEC_RESULT;
   udiCopyError      : RTS_IEC_RESULT;
   udiDeleteError1      : RTS_IEC_RESULT;
   udiDeleteError2      : RTS_IEC_RESULT;
   udiWriteError1      : RTS_IEC_RESULT;
   udiWriteError2      : RTS_IEC_RESULT;
   udiWriteError3      : RTS_IEC_RESULT;
   udiOpenError1      : RTS_IEC_RESULT;
   udiOpenError2      : RTS_IEC_RESULT;
   udiOpenError3      : RTS_IEC_RESULT;
   udiOpenError4      : RTS_IEC_RESULT;
   udiReadError1   : RTS_IEC_RESULT;
   udiReadError2   : RTS_IEC_RESULT;
   udiReadError3   : RTS_IEC_RESULT;
   udiCloseError1   : RTS_IEC_RESULT;
   udiCloseError2   : RTS_IEC_RESULT;
   udiCloseError3   : RTS_IEC_RESULT;
   udiCloseError4   : RTS_IEC_RESULT;
   udiSizeError : RTS_IEC_RESULT;
   udiDirDeleteError: UDINT;
   udiCreateError: UDINT;
Then paste this code into the editor.
xWrite_Trig();
//xWrite_Trig.PT:= T#500MS;
xWrite_Trig.CLK:= xWrite;
xStart_Write:= xWrite_Trig.Q;
xRead_Trig();
//xRead_Trig.PT:= T#500MS;
xRead_Trig.CLK:= xRead;
xStart_Read:= xRead_Trig.Q;
IF xStart_Write THEN
   xDone:= FALSE;
   IF xAppend_OverWrite THEN
   hFile:= SysFileOpen(szFile:= xFilePath, am:= ACCESS_MODE.AM_APPEND, pResult:= ADR(udiOpenError1));
   IF xAppend_OverWrite = FALSE THEN
      hFile:= SysFileOpen(szFile:= xFilePath, am:= ACCESS_MODE.AM_WRITE_PLUS, pResult:= ADR(udiOpenError1));
   udiPosError:= SysFileGetPos(hFile:= hFile, pulPos:= ADR(udiPos));
   IF hFile <> RTS_INVALID_HANDLE THEN
      xNew_Line:= concat('$n', xText_Write);
      IF udiPos = 16#0 THEN
         udiWrite:= SysFileWrite(hFile:= hFile, pbyBuffer:= ADR(xText_Write), ulSize:= INT_TO_UDINT(LEN(xText_Write)), pResult:= ADR(udiWriteError1));
      ELSE
         udiWrite:= SysFileWrite(hFile:= hFile, pbyBuffer:= ADR(xNew_Line), ulSize:= INT_TO_UDINT(LEN(xNew_Line)), pResult:= ADR(udiWriteError1));
      udiCloseError1:= SysFileClose(hFile:= hFile);
   xDone:= TRUE;
IF xStart_Read THEN
   xDone:= FALSE;
   hFile:= SysFileOpen(szFile:= xFilePath, am:= ACCESS_MODE.AM_READ, pResult:= ADR(udiOpenError1));
      udiBytesRead := SysFileRead(hFile:= hFile, pbyBuffer:= ADR(xText_Read), ulSize:=SIZEOF(xText_Read), pResult:=ADR(udiReadError1));
      xText_Read[udiBytesRead]:= 0;
   //xDone:= TRUE;
Be sure that you feed the TEXT_TO_FILE function block with a line that is already in a csv format for example,
variable1,variable2,variable3,variable4
You will see in the code that there is a xNew_Line variable that has the '$n' token to add the new line.
Hope this helps,
Best Regards
Johan
PostPosted: Wed Mar 14, 2018 8:25 am
Hi johan76swart, hi Primitive Source,
I've seen many similar examples of code like yours. For me, I want to have a program which can write and read a csv file in a certain directory. The problem is, that I couldn't figure out until now, where the file is saved/ or if I gave a certain file path, it wouldn't appear... It would mean a great deal to me, if you could enlighten me a bit!
Kind regards,
SpeedyG
PostPosted: Tue Jul 09, 2019 3:28 pm
VAR_INPUT
   xFilePath: STRING;
   xAppend_Pos: UDINT;
   xWrite: BOOL;
   xRead: BOOL;
VAR_OUTPUT
   xDone: BOOL;
// Write Variables
   xStart_Write: BOOL;
// Read Variables
   xRead_Trig: R_TRIG;
   xStart_Read: BOOL;
   xLine_Read: UDINT;
   udiWrite      : UDINT;
   udiPos         : UDINT;
//(* Error Codes *)
xWrite_Trig();
xRead_Trig();
   xDone:= FALSE;
      ELSE
   xDone:= TRUE;
IF xStart_Read THEN
   xDone:= FALSE;
   //xDone:= TRUE;
Hope this helps,
Best Regards
Johan
Hi johan76swart
do you have an exemple of the use of your function block please ?
cron
