It is currently Tue Oct 17, 2017 2:57 am
Post new topic  Reply to topic  [ 11 posts ]
PostPosted: Fri May 19, 2017 5:20 pm
Hi there,
I have seen some posts about the fieldbus coupler BK1150 from Beckhoff. None has helped. The provided MPD file only included BK1120. My scan in CoDeSys for attached components succeeds but I cannot get them running. I do not know why and would appreciate any hint or help.
Have a look at the attached image ...
PostPosted: Fri May 19, 2017 7:39 pm
hm... does this configuration reflext your real Hardware?
Is the `k-bus end terminal connected too?
PostPosted: Fri May 19, 2017 8:58 pm
Yes, though I have more modules available but they are not installed. The K bus is 'closed' by a KL9010.
If I get this running successfully it will turn out into a new job for me. So thanks for your efforts.
Greetz
Nicholas
PostPosted: Mon May 22, 2017 12:52 pm
No one?
The coupler is connected to eth0 (on board) and TCP network to eth1 with a USB-Ethernet adaptor.
Can I use any type of CAT cable for the EtherCAT connection? I need this running.
Thanks
PostPosted: Mon May 22, 2017 3:03 pm
you need to check this emergency message from screenshot in post 1
Maybe you get more informations in the plc logger...
check the documentation what this Emergency from the BK1150 reports.
PostPosted: Tue May 23, 2017 6:42 am
Unfortunately the ordinary manual does not provide that information. I am hoping for someone who could give me an example project. As far as I know I do not need to provide any startup parameters to the BK1150, right?
Nicholas
PostPosted: Tue May 23, 2017 6:43 pm
Hi Nicholas,
if you give me the full Emergency Information from PLC Logger... we could maybe check.
0x0E mean something PDO length is wrong (not really sure)
PostPosted: Tue May 23, 2017 7:27 pm
I cannot expand that message in CoDeSys. So that emergency message is all I have. The logs of the PLC show:
Greetz
Nicholas
PostPosted: Tue May 23, 2017 7:54 pm
AL Status 0x001E
Error Code 0x001E
Meaning:
Invalid Input Configuration
Description
SM configuration for input process data is invalid
Current State (or state change)
O, S, O, P→S
Resulting State
S + E
PostPosted: Tue May 23, 2017 8:05 pm
Hi Edwin,
your help is great. But it leaves me as a CoDeSys rookie still behind.
So do I have to provide startup parameters? And if what kind of. Sorry that I am lost. I really want to get into it.
Here is some more details on the error:
Greetz
Nicholas
PostPosted: Wed May 31, 2017 6:47 pm
Mission accomplished!
The coupler does not run with the normal BK1150 declaration from Beckhoff. It then throws the errors. What did help was to use the MDP variant of the BK1120 (!) and to disable the product ID check. The reason why I did not succeeded before was because of the confusing fact that some elements on the bus need two attached virtual devices per element in CODESYS, e.g. KL3458.
Finally all is up and running.
Greetz
Nicholas
