It is currently Tue Oct 17, 2017 7:24 pm
PostPosted: Thu May 18, 2017 2:58 pm
Hi All,
I have done various tests with ethercat on the raspberry Pi and codesys, including virtual drives etc.
However I would like to ask how to use a Beckhoff Ax5000 series drive and Am8032 Motor.
I have installed the Device repository and scanned the system and found the drive unit.
But at this point I am stuck, the ethercat does't run on the servo drive and I am not sure how to tell codesys the motor type.
Any pointers would be a great help thanks. :roll:
PostPosted: Fri May 19, 2017 9:09 am
Have you added the Beckhoff EtherCAT XML file?
You also need to add an axis to the solution tree, in here you can configure settings.
