It is currently Tue Oct 17, 2017 5:01 am
PostPosted: Thu May 18, 2017 12:23 am
Good evening,
I use this code to control modbus control
I use the digital outputs to control 6 on-board relays and analog inputs to check the status of relay relay-controlled relays to know their status.
I do not understand why when I pass an analog input into codesys i go high two inputs at a time.
I do not know if I made the problem clear but in case you could give me a hand?
Thank you, Alberto
#include <Controllino.h>  /* Usage of CONTROLLINO library allows you to use CONTROLLINO_xx aliases in your sketch. */
#include <ModbusRtu.h>
#define ID   2
Modbus slave(ID, 0, 0); // this is slave ID and RS-232 or USB-FTDI
int8_t state = 0;
unsigned long tempus;
// data array for modbus network sharing
uint16_t au16data[9];
void setup() {
  io_setup(); // I/O settings
  // start communication
  slave.begin( 9600 );
void loop() {
  // poll messages
  state = slave.poll( au16data, 9 );
  io_poll();
void io_setup() {
  pinMode(CONTROLLINO_D0, OUTPUT);
  pinMode(CONTROLLINO_D1, OUTPUT);  // note that we are using CONTROLLINO aliases for the digital outputs
  pinMode(CONTROLLINO_D2, OUTPUT);
  pinMode(CONTROLLINO_D3, OUTPUT);  // the alias is always like CONTROLLINO_
  pinMode(CONTROLLINO_D4, OUTPUT);  // and the digital output label as you can see at the CONTROLLINO device
  pinMode(CONTROLLINO_D5, OUTPUT);  // next to the digital output screw terminal
  pinMode(CONTROLLINO_A0, INPUT);  // next to the digital output screw terminal
  pinMode(CONTROLLINO_A1, INPUT);  // next to the digital output screw terminal
  pinMode(CONTROLLINO_A2, INPUT);  // next to the digital output screw terminal
  pinMode(CONTROLLINO_A3, INPUT);  // next to the digital output screw terminal
  pinMode(CONTROLLINO_A4, INPUT);  // next to the digital output screw terminal
  pinMode(CONTROLLINO_A5, INPUT);  // next to the digital output screw terminal
void io_poll() {
  // set digital outputs -> au16data[1]
  digitalWrite( CONTROLLINO_D0, bitRead( au16data[1], 0 ));
  digitalWrite( CONTROLLINO_D1, bitRead( au16data[1], 1 ));
  digitalWrite( CONTROLLINO_D2, bitRead( au16data[1], 2 ));
  digitalWrite( CONTROLLINO_D3, bitRead( au16data[1], 3 ));
  digitalWrite( CONTROLLINO_D4, bitRead( au16data[1], 4 ));
  digitalWrite( CONTROLLINO_D5, bitRead( au16data[1], 5 ));
  // get digital inputs -> au16data[0]
  bitWrite( au16data[0], 0, analogRead(CONTROLLINO_A0));
  bitWrite( au16data[0], 1, analogRead(CONTROLLINO_A1));
  bitWrite( au16data[0], 2, analogRead(CONTROLLINO_A2));
  bitWrite( au16data[0], 3, analogRead(CONTROLLINO_A3));
  bitWrite( au16data[0], 4, analogRead(CONTROLLINO_A4));
  bitWrite( au16data[0], 5, analogRead(CONTROLLINO_A5));
  // diagnose communication
  //au16data[6] = slave.getInCnt();
  //au16data[7] = slave.getOutCnt();
  //au16data[8] = slave.getErrCnt();
PostPosted: Thu May 18, 2017 12:39 am
Don't know anything about this but I'll take a guess:
Any chance it has to do with passing an INT value int a bit when you do bitWrite( au16data[0], 0, analogRead(CONTROLLINO_A0));
PostPosted: Thu May 18, 2017 9:18 am
Hi Comingback4u,
You've caught the problem !!
If I put to 1 input A0 I also activate bit 1
If I put to 1 A1 and I put to 0 A0 I activates bit 1 and bit 2 and so on.
In the picture I put A0 to 1 !!
How can I solve on Arduino code?
Thank you, Alberto
PostPosted: Thu May 18, 2017 2:38 pm
Solved !!
I hve onlychanged analogRead with digitalRead :)
Thanks for advice.
Alberto
PostPosted: Fri May 19, 2017 12:20 am
Glad I could help :D
Glad you got it working :D
Users browsing this forum: A. Akkerman and 5 guests
