It is currently Mon Oct 23, 2017 1:56 am
PostPosted: Wed May 17, 2017 9:37 pm
Hi There,
So i have been using my Pi for weeks successfully uploading a controlling programme and webvisu, talking to my Arduino Mega as a Modbus TCP/IP slave and this has been perfect :D . Then the other day Codesys just would not connect to the Pi. I can update the Runtime, this seems to load up to the pi, the Pi runs up to 25% on the CPU, the RX/TX lights on the Pi and the Arduino are flashing, but I when I type in the Pi's IP address in the Device section of codesys, it times out the first time, then I can't see the pi in the scan tree and just cannot connect or find the pi.
I tried formatting my Pi and reinstalling Raspian but I am getting the same problem.
Any ideas what could be wrong here?
PostPosted: Thu May 18, 2017 8:21 am
Primitive Source wrote:
Hi There,
Generallay if you write unstable things this kind of error will occur.
You need to delete application in your rpi.
follow this instructions,
1) sudo su //for administration
2) cd /root //go to the root folter
3) cd PlcLogic //go to the PlcLogic folter
4) cd Application //go to the Application folder
5) rm Application.app //delete Application.app
6) reboot rpi
7) update rpi via codesys
I hope it will work
PostPosted: Thu May 18, 2017 11:25 am
Thank you so much for your help :D
It worked perfectly! 8)
