Probably a stupid question but i have some troubles with rounding up numbers. So just like 3/2 = 2
It Always has to be rounded to the biggest number.
Any suggestions here? (i don't use the oscat library)
Many thanks.
I needed that conversation for getting the correct number of column and row, out of the (overall) count of an array (to correct the code of OSCAT's "CSV_PARSER_FILE_DEMO"). It works with the integrated truncation feature while calculating with integer values. Or you look after "ROUND" functions in OSCAT's library.
Hi all,
Many thanks.
So what do you want ?
If you want to be see 3/2 = 1.5
you have to define LREAL variable.
For example,
variable1 : LREAL;
variable1 := 3/2;
so, you can see variable1 = 1.5
There are many ways to always round up, but here is one:
Thank you. I tried it and it worked
a/b+((a div b)+(b-1))/b
My proposal for integer values:
