It is currently Sat Oct 21, 2017 9:25 am
 Post subject: txt file log
PostPosted: Wed May 10, 2017 5:18 pm
Hi, I am having issues with txt file logging using raspberry pi and can't work out where I am going wrong. I am creating a STRING called FINSTR, it contains data from a temperature sensor, humidity sensor etc. My process is basically as follows a tank is emptied and then it is filled, each time the tank is filled I have a BOOL FiWr that becomes true for a few seconds the stops. FINSTR is written to the the txt file each time FiWr becomes true. The issue I have is that rather than adding the FINSTR on a new line/append at the end of the file it just overwrites the existing data. I want the txt file to end up like this after a few cycles;
23, 199, 267,
28, 194, 267,
28, 193, 267,
But I am getting
23, 199, 267,
and then it is over written and the file reads
28, 194, 267,
FINSTR is a CONCAT of (SEMFINSTR, '$R$L'). I am using an altered version of the CAA File Standard example as per below.
xFileStdInit:= RUN;
IF NOT xFileStdInit THEN
filop(xExecute:=FALSE);
filcl(xExecute:=FALSE);
filwr(xExecute:=FALSE);
filrd(xExecute:=FALSE);
xFileStdInit:=TRUE;
uiFileStdState:=0;
ELSE
CASE uiFileStdState OF
0:(* create a new file *)
filop.sFileName:=sFileName;
filop.eFileMode:=FILE.MODE.MRDWR;
filop.xExclusive:=TRUE;
filop( xExecute:=TRUE);
IF filop.xDone THEN
hFile:=filop.hFile;
uiFileStdState:=1;
IF filop.xError THEN
(* error handling*)
1:(* close file - TestFile.txt *)
filcl.hFile:=hFile;
filcl( xExecute:=TRUE);
IF filcl.xDone THEN
uiFileStdState:=2;
IF filcl.xError THEN
(* error handling*)
2:(* end of example *)
END_CASE
IF NOT FiWr THEN
FiWr:= TRUE;
csvwrite:=0;
ELSE
CASE csvwrite OF
filop.eFileMode:=FILE.MODE.MAPPD;
IF filop.xDone THEN
hFile:=filop.hFile;
csvwrite:=1;
(* error handling*)
1:(* write text in the file *)
filwr.hFile:=hFile;
filwr.pBuffer:=ADR(FINSTR);
szFileSize1:=SIZEOF(FINSTR);
filwr.szSize:=szFileSize1;
filwr.udiTimeOut:=100000; (* 100ms Timeout *)
filwr( xExecute:=TRUE);
IF filwr.xDone THEN
csvwrite:=2;
IF filwr.xError THEN
(* error handling*)
2:(* close file - TestFile.txt *)
filcl.hFile:=hFile;
IF filcl.xDone THEN
csvwrite:=4;
(* error handling*)
3:(* end of example *)
END_CASE
For some reason if I open the file in MAPPD mode initially the file isn't created? This is why I have 2 cases, one that creates the file when the programme is set to RUN and the second case writes the data to the file each time FiWr is true.
I hope you can help me as it is driving me crazy?! :x
