It is currently Sat Oct 21, 2017 9:24 am
PostPosted: Fri Jun 23, 2017 10:07 pm
Hi All,
I have done various tests with ethercat on the raspberry Pi and codesys, including virtual drives etc.
However I would like to ask how to use a Beckhoff Ax5000 series drive and Am8032 Motor.
I have installed the Device repository and scanned the system and found the drive unit.
But at this point I am stuck, the ethercat does't run on the servo drive and I am not sure how to tell codesys the motor type.
Any pointers would be a great help thanks.
PostPosted: Sat Jun 24, 2017 4:59 am
you need to do two things for this:
1. Use a rt_preempt patched Linux Kernel/ SD Image on the PI
2. You need to have/use Twincat to export the SDO startup parameter (which contains drive and motorconfiguration) set them up in twincat / Export them as XML file and import them in CODESYS
see screenshot.
PostPosted: Wed Jul 12, 2017 9:28 pm
Thanks Edwin However I didn't see a screen shot suggested in your post
Users browsing this forum: alverman and 7 guests
