It is currently Thu Jul 20, 2017 11:30 pm
PostPosted: Thu Apr 27, 2017 1:55 pm
Hi, I'm trying to connect Raspberry with Siemens ET200SP by Profinet. I made Raspberry as IO Device and PLC Siemens as Profinet Controller, but communication doesn't work. Please check my configuration of Raspberry in CodeSys.
PostPosted: Thu Apr 27, 2017 3:16 pm
did you take care on this points here?
viewtopic.php?f=23&t=6247&p=16870#p16870
PostPosted: Fri Apr 28, 2017 4:51 am
I've seen this point but I don't understand one thing, Raspberry has only one LAN interface eth0, so do I have to add eth1 interface?
Otherwise I tryed to do things from your link, but when I execute command ifconfig eth1 promisc, the console receives this information: "eth1: ERROR while getting interface flags: No such device"
PostPosted: Fri Apr 28, 2017 4:59 am
sure you need to use eth0 if this is your profinet lan...
In my example there is a usb to ethernet adapter for profinet available,
