It is currently Sat Jul 22, 2017 1:43 pm
PostPosted: Tue Apr 25, 2017 1:49 pm
I need to use digital PWM signal, the current selection is Beckhoff EL2502 2ch PWM module. I added a device description file, but there are only 2 channels in IO MAPPING to adjust the duty option and no option to adjust the frequency.
I have consulted the documentation and the frequency needs to be written in the CoE cycle. I'm not quite able to understand this problem. I see EL2502 's startup Parameters with the PWM settings option to change the frequency, but I need to change the frequency with the requirements in the PLC. I suppose I could be configuring the Expert process data in EK1100. I don't quite understand how to relate it to a variable.
What I want to do is similar to Schneider's FB
EL2502 Module Documents at https://www.beckhoff.com/english/ethercat/el2502.htm
Thank you.
PostPosted: Tue Apr 25, 2017 2:16 pm
It looks like this setting can be used.
I don't have a module test yet, if someone has used it, please tell me if I can use it. Does it continue to output?
Thanks.
PostPosted: Tue Apr 25, 2017 6:42 pm
either map it to the PDO's or send the SDO from your application by SDO send.
http://store.codesys.com/ethercat-example.html
PostPosted: Wed Apr 26, 2017 8:01 am
Edwin Schwellinger wrote:
Thank you very much.
Users browsing this forum: A. Akkerman and 2 guests
