It is currently Sun Nov 19, 2017 12:17 am
 Post subject: Day event
PostPosted: Sun Apr 16, 2017 11:57 pm
Hi at all,
if I wanted to do one operation every day at the same time as I could make in LD?
Many thanks, Alberto
 Post subject: Re: Day event
PostPosted: Mon Apr 17, 2017 6:12 am
there is already an example here: viewtopic.php?f=23&t=6247#p12396
a little more details, one option would be
you could use timer2 from Oscat building library.
Install these two OSCAT libs Basic and Building in CODESYS (->shopping cart and then install by clicking in the embedded browser in CODESYS - download - sure you need to login to the store)
Then use attached Project example (not LD but CFC should be reasonable or at least you could easily translate this to LD)
PostPosted: Mon Apr 17, 2017 11:19 am
Thanks for the info, but I do not know how to insert the timer 2 graphic in my ladder.
how can I do ?
PostPosted: Mon Apr 17, 2017 2:27 pm
I managed to implement the code in my project by copying and pasting what I needed.
Now I do not know how to connect the Q output of timer 2 to a contact of my ladder.
Can you tell me how can I do?
Thank you, Alberto
PostPosted: Mon Apr 17, 2017 2:39 pm
PostPosted: Mon Apr 17, 2017 6:38 pm
many many thanks !!
PostPosted: Mon Apr 17, 2017 7:55 pm
it is normal that when you start the application on the active plc, timer2 the Q output even if the time is not the trigger?
alberto
PostPosted: Tue Apr 18, 2017 7:37 pm
Hi alberto,
guess yes, think this is 'as designed' - once a day you get this day event.. on first even if the time is already over
-> once a day - Q -> True.
Sure on the following days the time and Q does fit.
