It is currently Mon Nov 20, 2017 3:14 am
Post new topic  Reply to topic  [ 19 posts ]  Go to page 1 2 Next
PostPosted: Mon Apr 03, 2017 7:42 pm
have example to exchange data between 2 raspi ? I have problem to do that.
First one is "master":
- ethernetIP scanner/adapter
and other(s) is/are "slave":
- ethernetIP adapter/module ?
First one must generate eds files to configure other slave ?
Thanks for your helps.
PostPosted: Mon Apr 03, 2017 7:54 pm
galexis wrote:
Hi, you may be better off using network variables. Is this possible for this application?
Sent from my SM-N9005 using Tapatalk
PostPosted: Mon Apr 03, 2017 8:21 pm
On the future, more raspi "slave" will be added. I need to use ethernet ip.
PostPosted: Mon Apr 03, 2017 8:24 pm
I'm sorry, I do not understand what you mean?
PostPosted: Mon Apr 03, 2017 8:44 pm
In the future, 1 raspi need to control several raspi on ethernet ip. I don't want use network variables.
PostPosted: Mon Apr 03, 2017 8:50 pm
OK, I know this isn't going to help, I've never done this but I have seen it done and an example in this forum before.
PostPosted: Tue Apr 04, 2017 1:47 pm
Is there any solution right now? I wanna do the same thing.
PostPosted: Tue Apr 04, 2017 6:18 pm
I can't post my project here because is too big.
I want send 4 words and receive 4 words
One the first raspi, which is the mast:
I have add ethernetIP adapter (from eds ....) and set like this
PostPosted: Tue Apr 04, 2017 6:21 pm
one raspi slave(s):
I have add 8 "ethernetIP module" for each wir I want exchange
PostPosted: Wed Apr 05, 2017 7:04 am
Use network variables!
U just need to add a globals send list and a receive list.
The send lists must be exportet, once from raspi 1 and once from raspi 2.
After that you can import these lists as receive list on the different raspi's.
Search at the codesys help for: configuration of network variables.
There is a good step by step manual.
U don't need an adapter like ethernet then. The transfer is upd.
PostPosted: Wed Apr 05, 2017 12:17 pm
I understand your suggestion and I will test it, but I want to know how use EiP. In the future, raspi will communicate with industrial sensor in EiP.
PostPosted: Wed Apr 05, 2017 7:54 pm
The problem with network variables, is load of network: everyone device of network receive questions. On professionnal networ it's not good idea, I think.
PostPosted: Wed Apr 05, 2017 8:24 pm
The network variables are only on a local network shared by the raspberry pis and not the general public network. These should be kept seperate really.
PostPosted: Thu Apr 06, 2017 7:53 am
EIP Example with two PI's
viewtopic.php?f=23&t=6247&p=17450#p17703
With 3.5SP11 (July) there will be a 'device scan' available for EIP which will improve the commissioning a lot!
PostPosted: Sat Apr 08, 2017 10:17 pm
Thank you very much for your example.
When I try it on 2 raspi : it work.
On my project: it doesn't work. I have to force to "RUNNING" estate of adapter and scanner, but no exchange.
How do you "link" data on adapter/assemblies and each output or input in ethernet ip/module ? It's automatic or just add device ethernet ip module ?
Thanks for your help.
