It is currently Sat Jul 22, 2017 1:41 pm
PostPosted: Fri Mar 31, 2017 8:49 pm
Hi there,
I'm using RPI with Codesys and would like to know - is there any possibility to log the value of any variable to file, including some sort of timestamp. Is it possible without complex CSV or whatever file operations?
In my application I have a temperature sensor, which I want to log.
Thank you
PostPosted: Fri Mar 31, 2017 9:02 pm
syoma wrote:
Hi there,
Thank you
How long do you want to log the variable for and at what frequency?
Sent from my SM-N9005 using Tapatalk
PostPosted: Fri Mar 31, 2017 9:30 pm
For example, I have a PID controller, running at 100ms rate. I want to capture transient process of about 20 seconds by logging temperature and controller output every 100ms to make offline analysis and calculate better tuning coefficients for it.
PostPosted: Fri Mar 31, 2017 9:45 pm
OK. In my opinion the best way to do it is still using the standard libraries in Codesys.
See this thread for a good explanation.
viewtopic.php?t=7089
PostPosted: Fri Mar 31, 2017 9:54 pm
The oscat network library is the library you would need.
PostPosted: Sun May 07, 2017 5:20 pm
Hi, I am resurrecting this thread as I am having some issues with my CSV logging. I am using the CAA file library standard example for creating a CSV file, this works fine and this writes my string to a CSV file. The issue I am having is that rather than writing the string to the CSV file in a new line each time it is triggered to do so, it just overwrites the old data. I have opened the file in append mode and the last part of my string is '$R $N'. I am not sure where I am going wrong.
Does anyone know or have faced this issue before?
