https://forum.codesys.com/
Size of Memory in Raspberry
https://forum.codesys.com/viewtopic.php?f=21&t=7692
Page 1 of 1
Author:  aso3964 [ Tue Mar 21, 2017 2:38 pm ]
Post subject:  Size of Memory in Raspberry
I'm testing a program on raspberry with the following sizes:
Size generate code = 3,020,520 bytes
Size global data = 1,383,289 bytes
Total allocated memory = 4,213,566 bytes.
With this memory size, the CPU does not go into run mode.
I am using version 3.5.10
1. The problem is the size of the program?
2. If so, what is the maximum memory size for Raspberry?
Att
https://www.phpbb.com/
