Embedded Communication Gateway in RPi
2017-03-01
  • hermsen
    hermsen - 2017-02-28
    Dear Codesys users,
    It has come to my attention that some runtimes posses an embedded Communication Gateway, it seems this is also the case with the RPi.
    I am used to having the gateway installed on a local box (PC, laptop, whatever) and configuring it so that machine can contact the desired runtime. Also, the gateway proces can be installed/run on a networked machine. I before shortly was not aware that a communication gateway is embedded in the RPi and readily available.
    My question is simple: how should (can) I recognise that a communication gateway option is available in device X?
    Thank you
  • eschwellinger
    eschwellinger - 2017-02-28
    just add the gateway by the IPAdress (of the plc you want to check)...then select the new gateway, if the green circle occure,
    a gateway is embedded if not it stays red.
    IMG: CheckGateway.jpg
  • hermsen
    hermsen - 2017-03-01
    Dear Edwin,
    Thanks
