Hello everyone, I have to put in communication two RPI with Codesys.
The two have to exchange some variables between them.
What is the simplest and cheapest solution?
Thankyou in advance
Serghei
"c:\Users\<yourwindowsusername>\CODESYS Control for Raspberry PI\3.5.10.0\Documentation\RaspberryPI_CodesysV3_FirstSteps_EN.pdf"
here you should find this section:</yourwindowsusername>
This product supports the following functionalities:
-CODESYS EtherCAT Master
-CODESYS Profinet Master / Slave since SP10
-CODESYS Modbus TCP Master / Slave
-CODESYS Modbus RTU Master / Slave (serial interface must be supported by and installed in the OS)
-CODESYS WebVisu
-CODESYS SoftMotion CNC
-CODESYS OPC/UA Server
-CANopen via EL6751 Gateway
-CODESYS EtherNet/IP Scanner
-CODESYS EtherNet/IP Adapter
Thankyou in advance
Serghei
hi,
cheapest... -> none of them have extra costs every licenses included!
The options are:
Networkvariables (UDP)
ProfinetController - Profinet Device
Modbus TCP / Master - Slave
Ethernet/IP Scanner and Adpater
Netbase Services (see store example plc chat)
Hi Edwin,
Thankyou for the Answer
Ok i understand but if i want use ModBus TCP i need one Master License like this:
[url]
http://store.codesys.com/codesys-modbus-master-tcp.html
[/url]
And this license is included or no?!?!
For me i understand is not included, then i need one for master and slave is included.
Serghei
no, not needed if you read this FirstSteps pdf:
-CODESYS WebVisu
Very Cool
Thank You
