It is currently Thu Sep 19, 2019 1:29 pm
PostPosted: Mon Dec 04, 2017 1:52 pm
Hi everyone,
I have a problem using the RPi 3 Model B as a Profinet Master in Codesys.
My system is as follows:
I have a computer running Windows 7 with CoDeSys v. 3.5 SP11 to program the PLC. The computer is connected via a switch a raspberry pi 3 Model B and a profinet device. I installed the profinet device with a GSDML-file. The device is a SCHUNK EGL90 PN.
In CoDeSys I can find the RPi3. I added an Ethernet device and below this a profinet controler (with the IP of the RPi3) and below that the profinet device.
When I log in everything seems to work but I do not get any values (see screenshots CoDeSys_1 & CoDeSys_2).
Does anyone have an idea why? Do I have to switch lowbyte and highbyte and if yes, how do I do this?
I would be very grateful to get any tip!
rKtiC
PostPosted: Mon Dec 04, 2017 5:34 pm
everything seems ok,
you just need to map varibales.. then the process varibales should work.
(No mapping no processdata exchange)
PostPosted: Thu Dec 07, 2017 5:54 pm
Thank you for your answer Edwin.
Mapping the variables wasn't a problem but now it seems that I get values for only some of the BOOL-variables. The other ones are greyed out (screenshot ‘CoDeSys_3’).
Sometimes I got also values for other REAL-variables but then they disappeared again.
As you can see in screenshot ‘CoDeSys_4’ it looks like that port-001 of the PN-controller is not active. Could that be a reason? If yes, how can I activate it?
rKtic
PostPosted: Fri Dec 08, 2017 9:18 am
yes for me it is clear why.
PostPosted: Fri Dec 08, 2017 9:20 am
or use option 2:
update always Setting.
PostPosted: Tue Jan 02, 2018 12:40 pm
Happy New Year!
Everything works now. The two bytes of status and control word have to be swapped.
Thanks for the help!
PostPosted: Tue Jul 24, 2018 10:00 pm
Well, dont know what i did wrong. When i scan for device i can see my Kuka robot and ip adress that i set on KRC, but got this error?
PostPosted: Wed Jul 25, 2018 6:22 am
which error do you mean - there is no error - next step is to select the line in this scan dialog and exceute
'Set Name + IP'.
-> then 'copy all devices to project' - and do a new download
PostPosted: Wed Jul 25, 2018 6:49 am
thx Edwin, think i try that, but nothings happend? Will try again today, and post results!
BG
PostPosted: Wed Jul 25, 2018 8:06 am
me again, now thats the error, but ip adress in krc is set to valid range
PostPosted: Wed Jul 25, 2018 9:46 am
wow stupid mistake, i solved my issue :)......connected all eth interfaces on unmenaged switch, nad everythings works at glance :)
PostPosted: Fri Jul 27, 2018 10:53 am
Important Information for PI3B plus and current Raspbian:
If someone is using PI3B+ with Profinet Controller / Device on eth0.
There is a known issue with current Raspian and new Ethernet Driver:
the following steps are needed:
sudo apt install vlan   # VLAN-Paket installieren
sudo modprobe 8021q     # 8021q Kernelmodul laden
loading the kernel module could be done on restart by:
sudo su -c 'echo "8021q" >> /etc/modules'
PostPosted: Wed Mar 27, 2019 5:30 pm
Hello Edwin,
Is this already fixed?
Thanks
Bruno
PostPosted: Wed Mar 27, 2019 8:09 pm
hm.. guess not,
this need to be added to the RASBIAN Image by Rasbian.org
