It is currently Sat May 25, 2019 8:35 pm
Post new topic  Reply to topic  [ 24 posts ]  Go to page 1 2 Next
PostPosted: Tue Sep 27, 2016 9:08 pm
Hy.
I am a newbie to codesys, it seems very a powerful tool with raspberry pi and I want to try to adapt it to play with automotive. I saw that codesys can implement google map, is possible to show in webvisu the location (latitude and longitude readed from GPS module) in google map.
I saw that feature but I did not find any example:
PostPosted: Tue Oct 23, 2018 2:34 pm
May I ask if you have found a solution or a sample for your task?
Cheers,
CanBohr
PostPosted: Tue Oct 23, 2018 5:15 pm
in this CODESYS Forum in the following section:
CODESYS V3 Raspberry Pi share your devices & libraries & applications
viewtopic.php?f=23&t=6247&start=15#p16175
PostPosted: Thu Oct 25, 2018 5:01 am
Edwin Schwellinger wrote:
Which runtimes support GoogleMaps NativeControl? Only Raspberry runtime?
Make CODESYS great again
PostPosted: Thu Oct 25, 2018 9:43 pm
the example is webvisu based...
PostPosted: Fri Oct 26, 2018 5:47 am
Ok, but what should I do to support it on my device?
PostPosted: Thu Dec 06, 2018 9:43 pm
Hi e.kislov,
have you solved the problem?
If yes please let me know.
Cheers,
CanBohr
PostPosted: Fri Dec 07, 2018 4:47 am
Not yet, I still waiting for answer from Edwin. :)
PostPosted: Fri Dec 07, 2018 1:44 pm
this is only possible to use in the webvisu,
so please remove the targetvisu from that application.
PostPosted: Fri Dec 07, 2018 8:44 pm
Hallo Edwin,
Bei mir ist nur die Webvisualisierung vorhanden, dennoch kommt der Fehler 3s.NativeControl.GoogleMaps ist nicht verfügbar.
Oder liegt das an der Simulation?
Gruß,
CanBohr
Gesendet von iPhone mit Tapatalk
PostPosted: Fri Dec 07, 2018 9:30 pm
Klar das geht nicht in Simulation nimm doch einen PI oder Control Win..
Grüsse
PostPosted: Sat Dec 08, 2018 6:35 am
Danke.
Werde ich dann so machen.
Kannst Du mir noch verraten, was Control Win ist.
Gruß,
CanBohr
PostPosted: Sat Dec 08, 2018 7:56 am
das ist die SPS die mit CODESYS auf deinem PC mit installiert wird.
Control Win: Vollwertige SPS (keine harte Echtzeiteigenschaften, wenn man das braucht-> Control RTE nehmen) kann Ethercat/Profinet/Ethernet/IP .... kannst also alles auf deinem CODESYS PC machen.
Für die Webvisu dann http://localhost:8080/webvisu.htm aufrufen
PostPosted: Sat Dec 08, 2018 2:47 pm
Vielen Dank für Deinen tollen Hinweis.
Liebe Grüsse,
CanBohr
PostPosted: Sun Dec 09, 2018 8:52 pm
Hallo Edwin,
Es funktioniert leider noch nicht.
Ich habe die Software jetzt auf dem Raspi.
Das Ergebnis ist leider dasselbe.
Die Control Win habe ich auf meinem Rechner auch noch nicht gefunden.
Es wäre schön, wenn Du mir noch einen Tip geben könntest.
Bislang nutze ich ein Webbrowserelement, das ich mit dem Aufruf Google Maps zusammen mit den Koordinaten Aufrufe.
Gruß,
CanBohr
