I am having a problem with starting a script via CODESYS. My goal is to create a screenshot via a button click or via an input. For doing this I am using the
"Sys Process Execute Command" command (no spaces of course, but it screws up the layout somehow). I altered the CODESYSControl.cfg to
[SysProcess]Command=AllowAll
and I created a script named takeScreenshot which looks like:
\#!/bin/shDISPLAY=:0scrot-d1'screenshot.png'
I made it executable with
sudochmod+x/usr/bin/takeScreenshot
Finally I tested the script with typing ```
takeScreenshot
``` in the terminal and it works like a charm.
So I started to implement the command in Codesys like this:
Now the problem: It does not work
As a result I get "0" and no screenshot. But if I am trying another command like "reboot" or "ifdown" it works without any problems. I dont have a clue. Can someone help?
Thanks and Greetings
Andy
thank you for your reply.
Unfortunatly the command is not executed by the Raspberry Pi (unlike a reboot command or similar). So no log is being created. Although it works when I am typing the exact same command in the Raspi terminal.
Greetings
Andreas
Hello together,
takeScreenshot
Andy
You could pipe the console output to a file and see what turns up. Perhaps something like this
Hi Rick,
Greetings
Andreas
In the Codesys Log (cat /tmp/codesyscontrol.log) I get the following message
I tried to use "" as sCommand as well with the same result.
