Good afternoon,
i try to configure a I/O I2C Board with 8 input and 8 output.
In this moment i can see the board, but i have no idea how force the output.
In the exaple of MCP23017 library for me is not clear how to use a instructions.
There is a other documentation or some forum user that have use this library ?
Thank you all !
Good afternoon,
Thank you all !
Hello I also try to use library from this post:
https://forum.codesys.com/viewtopic.php?f=23&t=5872&p=10868#p11014
Unfortunately I am not able to force output even IO variable is set to "16#00"
(I am using RPi v3)
Update:
There is a problem with IO configuration -> its fixed FF (all inputs)
Maybe I cannot call init procedure properly....
I change it in library to 16#F0 to have half port as in and half as out and it works..
Can someone change it during operation??
