but I was just wondering the same(ish) thing:
Is there a way in Codesys 3.5 with the 3.5.14.20 Pi Runtime to create tasks
that will only be called once during startup/shutdown of the PLC?
In my program I am opening a file in the local filesystem and
if I stop or logout the program with a file handle opened
it will raise an exception and I will have a bad time.
Therefore I was thinking that I could write a task which would
close any opened filehandles in order to shutdown gracefully.
Thanks in advance!
Task Configuration - System Events - Add Event Handler - Select event (PrepareStart, PrepareShutdown, etc.) - enter name for new (not existing!) function - add implementation.
Is this possible w/ the r-Pi?
On another plc in CodeSys v3.1, I could configure task type = External, event = on_Start. But I don't have these options for the r-pi, v3.5.
Any way to do this? Is this a difference specific to ver 3.5 of CodeSys, or the r-Pi, or both?
Hello and sorry for gravedigging,
Thanks in advance!
Hey,
