Your example on youtube is very clear and simply to follow https://www.youtube.com/watch?v=6FPf3RHWyeU , but then I have some problem in two different pc as you can see on the attached image.
After installing codesys V3 last version, I installed raspberry package and try to open webvisu example I see the attached image.
Where I fail?
Image is not attached,
guess your Problem could be solved by 'UpdateDevice' see screenshot
check compilerversion and Visuprofile too. (set it to 3.5.8.0) ->Project settings
Where I fail?
