It is currently Wed Feb 20, 2019 10:31 pm
PostPosted: Thu Dec 03, 2015 8:12 am
I want to play AUDIO files with my RPI2. What do I have to do in Codesys? My idea is to play AUDIO files when some digital bit is ON.
regards
PostPosted: Thu Dec 03, 2015 3:34 pm
Hello:
Enable commands at /etc/CODESYScontrol.... (do not remember right name), add to settings:
[SysProcess]
Command=AllowAll
OR more safety:
[SysProcess]
Command.0=aplay
Command.1=mplayer
In Codesys program add variable:
   cmdResult   :    RTS_IEC_result;               // Command Result
And use command for play the sound (for aplay command):
SysProcess***ExecuteCommand('aplay /theway/tomusic/sound.wav', ADR(cmdResult));    // Delete that "***", I have to add it because forum filtering it
Remember, that program will stop at command until the sound is played. Its better to make 2nd Task for sound playing with using some buffer or mark at GLOBAL VARIABLE.
IF soundState THEN SysProcess***ExecuteCommand('aplay /theway/tomusic/sound.wav', ADR(cmdResult)); soundState:= FALSE; END_IF     // Delete that "***", I have to add it because forum filtering it
Maybe you have to add library:
SysTypes Interfaces
SysProcess
PostPosted: Fri Dec 04, 2015 7:05 pm
Thank you! This worked fine.
PostPosted: Sun Mar 13, 2016 3:23 pm
SysTypes Interfaces
SysProcess
Hallo jvondrus,
How can I add this library?
Thanks, your help!
regards
PostPosted: Sun Mar 13, 2016 4:12 pm
see screenshot just type in what you know from the library - name of an FB or name of the Lib
PostPosted: Tue Nov 15, 2016 8:28 pm
I am currently testing a video file with:
Video_1: STRING: = 'sudo omxplayer -o both /home/pi/media/test.mp4';
The file is also played via the "omxplayer".
Works perfect,
But how can I finish playing that prematurely?
In the terminal I press "q"
is that possible?
Thank you very much
mfg mike
PostPosted: Mon Mar 20, 2017 7:23 pm
Edit: I got it working. Now that I have an account I can see the screenshot mentioned above. Just an addition, I had to click on the "display advanced libraries" in the Add Library window.
I am interested in getting this code to work on my Raspberry Pi 3 using CODESYS V3.5 SP10 P2 +. I have SysTypes Interfaces (3.5.2.0) and SysProcess (3.5.7.0) installed. I'm very new to CODESYS and Raspberry Pi.
In declaring the variable cmdResult, there is an error "Identifier 'RTS_EIC_result' not defined". I also tried
cmdResult   : POINTER TO RTS_IEC_result;
but I get the same error.
Also, regarding the SysProcess***ExecuteCommand (minus the ***) I have the same "Identifier not defined" error. Is there an "Import" that I'm missing?
jvondrus wrote:
Hello:
PostPosted: Tue Oct 30, 2018 8:24 pm
I also have the same error RTS_IEC_RESULT Module not found, does anyone knows how to solve this problem.
Thank you best regards
