It is currently Sun Jul 23, 2017 3:36 am
Post new topic  Reply to topic  [ 16 posts ]  Go to page 1 2 Next
 Post subject: SPI Device
PostPosted: Sun Nov 01, 2015 9:02 am
How can I create a new device? I need to make communication between RasPi and my board through SPI port. There is an example for device MCP3008 but I can't find the way how to modify it
 Post subject: Re: SPI Device
PostPosted: Sun Nov 01, 2015 9:25 am
HI,
see the documentation here for details:
"c:\Users\YourWindowsUsername\CODESYS Control for Raspberry PI\2.2.0.2\DataSheet\RaspberryPI_en.pdf"
The devices and libraries which you could use as startpoint are here:
"c:\Users\YourWindowsUsername\CODESYS Control for Raspberry PI\2.2.0.2\Devices"
"c:\Users\YourWindowsUsername\CODESYS Control for Raspberry PI\2.2.0.2\Libraries"
PostPosted: Wed Nov 04, 2015 12:11 pm
There are examples good for startpoint overview, but now I want to create my own device for my own board with some binary IO. Is there any way to create a new device?
PostPosted: Wed Nov 04, 2015 3:08 pm
Ok, I got it, this pdf, page 17
PostPosted: Thu Nov 05, 2015 11:29 am
I work around IoDrvPiFace a and I trying to change channels in "SPI devices I/O Mapping". What is the way to do it? In method "IoDrvUpdateConfiguration" is part:
   //Setup I/O area
   pParameter := IoMgrConfigGetParameter(m_pConnector, 1000);      (* inputs *)
   IF (pParameter <> 0) THEN
      pParameter^.dwDriverSpecific := 0;               (* Device offset 0 *)
   pParameter := IoMgrConfigGetParameter(m_pConnector, 2000);      (* outputs *)
In pdf "Creating own Runtime System Components and I/O Drivers" on page 12 is:
  • Inputs: 1000-1999 (type:DWORD)
  • Outputs: 2000-2999 (type:DWORD)
but after modifying this values, in project nothing was change, I want to add some IO bytes more.
V.
PostPosted: Fri Nov 06, 2015 1:55 pm
Maybe it is not easy to understand what I need. So, can someone add an input or outbut byte in IoDrvPiFace.library? I need to see it in SPI Devices IO Mapping.
Thanks, Viktor
PostPosted: Wed Nov 11, 2015 2:36 pm
No answer :(
I believe anyone want to to help but its not clear what I want.
At first, we are developing control system based on Raspberry Pi and additional FPGA boards. Its mean mainly for cnc controller LinuxCNC but we looking for additional field of use of same hardware. We are done with IO binary board (16inputs/16outputs) and I trying to make IO driver for Codesys. More info about system for LinuxCNC:
https://youtu.be/ZJOIYXu7SeI
It is possible to help me and show how to modify IoDrvPiFace.library and add some more I/O which are visible in SPI Devices I/O Mapping?
PostPosted: Mon Nov 30, 2015 7:30 pm
Hi VikTan,
if you want provide an SPI Driver for your device you need to add your library and your devicedescription for your device.
Maybe PiFace_Io_driver is the startpoint you need.
In the device description which you find here:
"c:\Users\<yourWindowsUsername>\CODESYS Control for Raspberry PI\2.2.0.2\Devices\PiFaceIOdrv.devdesc.xml"
library here:
"c:\Users\<yourWindowsUsername>\CODESYS Control for Raspberry PI\2.2.0.2\Libraries\IoDrvPiFace.library"
This documentation for the runtime toolkit is not really useful for adapting Drivers for raspberry pi, this is more or less used if you buy the toolkit
and adapt a driver in C.
This SPI/I2C and other devices are implemented in IEC Code and need additional a devicedescription.
For Information on how to develop IEC libraries see the Store pdf and additional the FAQ section here in the Forum for best practice on
how to devel libraries (two instances on opens the library the second CODESYS instance open the project and test/debug your code even step into the library is possible )
PostPosted: Tue Dec 01, 2015 11:22 am
Hi, thanks for answer
I already tried all this steps what you wrote. Something if working something not.
Consider the example, original PiFace_IO_Driver:
Is it possible to add some new variable by editing PiFaceIOdrv.devdesc.xml or IoDrvPiFace.library?
I assume yes and for someone who are experienced in codesys is it question of few steps and few minutes.
If someone can, pls describe me how to add any variable to this place. Step by step or something in particular what can help me to move to forward, not only general here is examples good for start.
Thank you in advance for any help
PostPosted: Thu Dec 03, 2015 7:58 am
Hi VikTan,
give me some time to generate some more documentation for this..
PostPosted: Thu Dec 03, 2015 8:30 am
I'll be very grateful :)
PostPosted: Mon Mar 07, 2016 8:23 am
I am facing the very same situation as OP.
I want to add interface variables (IO Mapping) but don't know how to to that.
Did someone update the documentation? If yes where to find it?
PostPosted: Wed Mar 16, 2016 3:52 pm
Edwin helps me with some points. Here is simple modified program PiFace with added variables.
https://www.dropbox.com/s/c0zie4snrtgyrl2/Example_project.zip?dl=0
Look mainly to "IoDrvReadInputs" and "IoDrvWriteOutputs" there is connection between project and library
Regards
Viktor
PostPosted: Tue Nov 29, 2016 9:27 am
Hello VikTan,
Your link seems dead, would it be possible for you to repost it ? I am in a similar situation and that would be of great help, I need to develop a SPI library for a raspberry hat in order to use it with codesys and I am a bit confused on how to do it.
Thank you in advance,
PostPosted: Thu Dec 15, 2016 12:04 pm
Hello everybody,
I want to use RC522 rfid IC with raspberry pi:
https://www.amazon.de/gp/product/B00QFD ... UTF8&psc=1
It supports both spi an i2c. Any suggestion where to start?
Thanks,
Gergö
