Setup:
Wired LAN Connection via dedicated router
Both laptop and RPi configured with static IPs
Windows Firewall is disabled
Codesys V3.5 SP7 Patch 1
Codesys for RPi Ver 2.2.0.2
What I have done/checked:
PING works both ways
TOOLS/UPDATE RaspberryPi finds RPi and UPDATE works (V3.5.7.10)
Tried setup without Router but problem persists
Updated to the latest Raspbian (2015-09-24-raspbian-jessie)
Please could somebody please suggest a solution
Thanks
I've tested with:
2015-09-24-raspbian-jessie.img
After deploying (by 'Update RaspberryPI' command) the runtime on the raspberry pi based on this raspbian-jessie
works without problems.
Don't forget to enable SPI,I2C by sudo raspi-config if you try to connect and use SPI and I2C devices.
When doing a Network Scan the RPi is not found
Setup:
Thanks
hm.. I need to try 2015-09-24-raspbian-jessie.
even here I would try this:
connect by ssh to the Pi(putty)
then
sudo apt-get updatesudo apt-get dist-upgradesudo rpi-update
If this does not solve it please send me the Output of /tmp/codesyscontrol.log
(cat /tmp/codesyscontrol.log)
Hi
I've tested with:
Thanks Edwin,
that seems to have fixed the problem.
