It is currently Tue Feb 18, 2020 1:19 am
Post new topic  Reply to topic  [ 31 posts ]  Go to page Previous 1 2 3 Next
 Post subject: Re: CPU Temperature
PostPosted: Wed Nov 18, 2015 3:03 pm
hi,
but this is not 3.5.7.x Version which you are using isn't it?
In older versions -> switch to professional feature set in current Version this should work without problems.
PostPosted: Wed Nov 18, 2015 3:30 pm
hi
I am using v3.5 sp3 patch 3 +
PostPosted: Wed Nov 18, 2015 3:31 pm
any chance for updating the CODESYS Developmentsystem?
BNR
PostPosted: Wed Nov 18, 2015 3:38 pm
ok sorry how do I do this ?
PostPosted: Wed Nov 18, 2015 3:52 pm
here you could download the CODESYS Developmentsystem in current version:
http://store.codesys.com/engineering/codesys.html
-Install it.
-Install the Raspberry PI Package in the PackageManager in CODESYS.
PostPosted: Thu Nov 19, 2015 11:53 am
I uninstalled everything and installed codesys v3.5 sp7 patch 3 and codesys control for raspberry pi 2.2.0.2 .
I still can not add the library , but when I open the example project It works .
PostPosted: Thu Nov 19, 2015 2:00 pm
you mean if you type: SysProcess (in the green field?)
This does not occure like in in my screenshot
PostPosted: Thu Nov 19, 2015 8:06 pm
Yes , it is like the screenshot that I attached earlier , when I type in sys in the search field there is no library named SysProcess .
PostPosted: Tue Aug 23, 2016 2:58 pm
Edwin Schwellinger wrote:
I have the same problem also, I am running V3.5 SP9 patch1 and when I type SysProcess there is no matching libraries.
PostPosted: Tue Aug 23, 2016 4:31 pm
All,
I found the solution... apparently this is an "Advanced" library. So in order for it to be visible to be added you have to click the little "+" icon on the add library window.
PostPosted: Sat Sep 16, 2017 11:53 am
Dears.
I have try to use this method to read the temperature in a patched_rt kernel.
I had to pass the function to an assync task, if not watchdog rises.
But passing to assink, the jitter in main task increases to some ms. I sopose that is caused because the external call is made with same priorities as cidesys is running and the main task interrupt is blocked.
Can I call the system function changing process owner or priority or....
PostPosted: Mon Aug 19, 2019 2:46 pm
Hello everyone
I am a programming novice. I tried to use the function described in previous
posts.
But I am not sure what I am doing wrong. I do not get a temperature back.
When I type it in the command window of the Pi I get a temperature.
I only want to read it every 2000th cycle.
Thanks for any suggestions.
Andreas
PostPosted: Tue Aug 20, 2019 7:00 am
did you enable the command in /etc/CODESYSControl_User.cfg ?
[SysProcess]
Command.0=shutdown
Command.1=yourshellcommand
Last edited by Edwin Schwellinger on Tue Aug 20, 2019 8:19 am, edited 1 time in total.
PostPosted: Tue Aug 20, 2019 8:07 am
Dear Edwin
I added your suggestions to the CODESYSControl.cfg file but it is still not working.
I bootet the whole system.
Any other hints?
Thanks Andreas
PostPosted: Tue Aug 20, 2019 8:18 am
sorry remove it from /etc/CODESYSControl.cfg
my fault it should be in /etc/CODESYSControl_User.cfg
and
yourshellcommand = vcgencmd ;-)
or possible is (either allow single commands or all):
[SysProcess]
Command=AllowAll
to allow every shell command
