It is currently Sat Feb 22, 2020 5:05 pm
PostPosted: Wed Feb 04, 2015 10:57 pm
The raspberry Pi and some one wire temp sensors from Dallas DS18B20 are giving me a hard time.
When I login white SSH than I can read the temperature white the cat commando.
but when i login in the raspberry Pi white codesys with then I get only the address from the sensors.
but no readings. what do I do wrong?
In the status window is the message "no driver found" is this normal?
Regards Lammert,
PostPosted: Sun Feb 22, 2015 11:46 am
Hi there!
I have exactly the same problem (No driver found) like lvdPol.
Please help us...
Regards
T. Holsten
PostPosted: Sun Feb 22, 2015 12:28 pm
please check the following:
1. did you add the ID of your sensor in the configuration tap of the 1wire sensor.
2. what does Linux report if you connect to your pi by ssh (putty)
and give then the following command cat /sys/devices/w1_bus_master1/28-0004442100FF
<28-0004442100FF> should be your sensor ID which you see in the table
If this is set and it still does not work you need to check if your sensor does work under Linux
cd /sys/bus/w1/devices
cd <yoursensor-ID>
cat w1_slave
0f 00 4b 46 ff ff 06 10 0c : crc=0c YES
0f 00 4b 46 ff ff 06 10 0c t=7375
Did you add the 4k7 resisitor ?
Here is a good description:
http://www.google.de/imgres?imgurl=http ... CD4Q9QEwAw
PostPosted: Mon Feb 23, 2015 5:21 pm
Danke! Jetzt funktionierts.
Punkt 1 hatte ich ├╝bersehen.
