It is currently Wed Feb 26, 2020 6:24 am
 Post subject: How to get system time
PostPosted: Thu Jan 29, 2015 11:50 pm
Hi all
Does anyone know how to read the system time from rasbian to use in CoDeSys?
The Raspberry is set up for ntp, and i would like to use that for a project where i need actual time and date without the need to readjust the clock after a power off.
Probably there is already a function somewhere and i just have not found it
Helpful could also be the possibility to run a pyton/php (or any other language) script on rasbian by codesys code and read in the result...
Thanks for help, i work for years with codesys, but our controllers have RTC and we don't do the integration by our self :)
PostPosted: Fri Jan 30, 2015 6:20 am
use attached example,
(* get time in seconds since 1970 *)
udiUtcTime := SysTimeRtcGet(udiResult);
IF udiResult <> 0 THEN
   RETURN;
END_IF
(*converts the utc time (seconds) to a SYSTIMEDATE with year, month , day, and time etc. *)
udiResult := SysTimeRtcConvertUtcToDate(udiUtcTime, strTimeDate);
   RETURN;
END_IF
(*converts the utc time to the local time, regarding timezone and summer time in seconds *)
udiResult := SysTimeRtcConvertUtcToLocal(udiUtcTime, udiUtcTimeLocal);
   RETURN;
END_IF
The projectarchive is using the calendar from the oscat libraries too!
PostPosted: Fri Jan 30, 2015 9:43 am
Hi Edwin
Big thanks for the fast help and the working solution, perfect!
Cheers
impius
