It is currently Sun Feb 23, 2020 5:37 pm
PostPosted: Tue Feb 18, 2014 12:02 pm
Hi guys,
Really encouraging platform you've developed here, especially as I'm going into final year and need project idea's.
In my current work I have the eDAM-5029 Remote IO device communicating with my Pi through MODBUS TCP Protocol (through sockets).
I'd love to get it up and running with the CODESYS application However I keep getting the CmpIecTask library error when I add
"Modbus Master -> Modbus Slave" devices.
If someone could point me in the right direction in terms of configuring my device in the software it would be greatly appreciated.
Manual: http://www.audon.co.uk/downloads/EDAM5000_Manual.pdf
-Sean.
PostPosted: Tue Feb 18, 2014 9:23 pm
this should work, how do you get the CmpIecTask library error,
this should not happen?
Try to create an empty new Project with Raspberry Pi as plc.
Then add Ethernet - then Modbus-Master then Modbus-Slave (under the Modbus Master).
Compile - the this should lead to an error free compile result.
If not let me know.
E.Schwellinger
PostPosted: Thu Feb 20, 2014 11:43 am
Still getting the error(s)..
Here's a screenshot (attached below)
This guy also had the same problem and managed to get it fixed:
http://www.raspberrypi.org/phpBB3/viewt ... 70#p507270
Cheers,
Sean.
PostPosted: Fri Feb 21, 2014 9:05 am
CODESYS Control for Raspberry Pi.devdesc.zip
there's an error in the device description of "CODESYS Control for Raspberry Pi".
This is only a problem if you use CODESYS V3.5.4.10.
I attached a corrected version of the device description. Just install this device (Tools -> Device Repository... -> Install...) and then update your device in the device tree or restart CODESYS.
Best regards
3S Support
PostPosted: Fri Feb 21, 2014 10:13 am
Many thanks for the support.
A member of your technical support team managed to remote in to my system and resolve this issue.
My eDAM IO unit is now up and running as a MODBUS TCP Slave (and only ~9% CPU on the RPi)
Cheers Guys!
PostPosted: Sat Jan 24, 2015 12:11 pm
Hi Everyone, having codesys run on he pi is brillant.
Ok, i have the Adam 6050 Modbus TCP slave (12 in, 6 out). I've configured codesys with a modbus tcp master and modbus tcp slave and entered ip address of the slave. However codesys tells me the ModbusTcpSlave is not running. The device appears ok as i can connect to it via service tool. Any tips?
Thanks
PostPosted: Sun Jan 25, 2015 11:30 am
My mistake, got it working. Here is screendump of working setup. Problem was i used "FC23 Read/Write Multiple Registers" and i dont think the 6050 supports this. From 6050 manual, it says:
Code (Hex)
Name Usage
01 Read Coil Status Read Discrete Output Bit
02 Read Input Status Read Discrete Input Bit
03 Read Holding Registers Read 16-bit register. Used to read integer or floating point process data.
04 Read Input Registers
05 Force Single Coil Write data to force coil ON/OFF
06 Preset Single Register Write data in 16-bit integer format
08 Loopback Diagnosis Diagnostic testing of the communication port
0F Force Multiple Coils Write multiple data to force coil ON/OFF
10 Preset Multiple Registers Write multiple data in 16-bit integer format
so i tried Function code 03 for read inputs and Function code 15 (16#000F) for write outputs. Once did this, all good.
