It is currently Fri Feb 28, 2020 1:03 am
 Post subject: system command result
PostPosted: Wed Oct 29, 2014 12:53 pm
Please explain us how we can take return result in Plc application of system commands like:
"cat /proc/cpuinfo "?
Regards
PostPosted: Wed Oct 29, 2014 8:10 pm
use this project from this link, and feel free to modify it to your needs:
viewtopic.php?f=21&t=5923#p11084
change szFilename: STRING := '/proc/cpuinfo';
and somehow you need to get your information from the buffer which contains then /proc/cpuinfo ... see screenshot
PostPosted: Mon Nov 03, 2014 12:11 am
I try your solution but it gives a result string of 278 characters only, not include the serial number.
Is there any solution to call from codesys runtime a shell command and take the result?
Regards.
PostPosted: Mon Nov 03, 2014 5:50 am
you need to specify your startpos to read see screenshot.
PostPosted: Mon Nov 03, 2014 6:40 am
Is there any other way to run OS command and take back the result?
Because if I use your solution I can't run commands like in shell mode.
Regards
PostPosted: Mon Nov 03, 2014 7:50 am
you can call every shell command but you do not get the result/output of them back to the iec world.
that's the point, so you need in this case to use the char device example.
Regards
PostPosted: Mon Nov 03, 2014 9:04 am
How can I use the command "grep -i serial /proc/cpuinfo | cut -d" " -f2" with chardevice and take the result?
Regards
PostPosted: Mon Nov 03, 2014 9:15 am
that's what I already said:
It is not possible to get the result to the iec world...but you have a workaround!
