Modbus RTU RS485
sallos
2014-10-11
2014-10-21
  • sallos - 2014-10-11
    iam searching for a MODBUS RTU Lib with RS485 Support.
    I have an TTL -> RS485 converter on the Raspi, but i must switch the send/recv by a output.
    The Converter is standart at recv an wen the Modbus Master sende they musst switch it.
    Have anyone a idear?
  • mbruck - 2014-10-21
    Hi!
    Long time I'm using simple transistor + 75176 IC, bit I believe it can be also max486. It switch automatically independent of speed (I test it with 230kbs and it work). If you able to make your pcb I can send you schematic if you like.
