It is currently Sat Dec 07, 2019 5:50 pm
Post new topic  Reply to topic  [ 59 posts ]  Go to page Previous 1 2 3 4
PostPosted: Thu Nov 09, 2017 10:47 am
no i alreade changed this like you mentioned in your previous post:
Quote:
6.add/change to /etc/CODESYSControl.cfg
[SysFile]
FilePath.1=/etc/, 3S.dat
FilePath.2=/media/, *.app, *.crc
move CODESYSControl.cfg and 3S.dat to your new location - in my case /media/
I just change the entry to this:
Quote:
[SysFile]
FilePath.1=/etc/
FilePath.2=/media/, *.app, *.crc, 3S.dat
Still not working... :cry:
EDIT:
Missing license is just for Profinet right?!?!?
PostPosted: Thu Nov 09, 2017 11:16 am
[SysFile]
FilePath.1=/media/, 3S.dat
if you see a message in the logger 'missing license file'
all fieldbus licenses/webvisu is missing.
You are using 3.5SP11 runtime - right?
PostPosted: Thu Nov 09, 2017 2:15 pm
yes, 3.5.11.10:
Package-Info:
root
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name           Version      Architecture Description
ii  codesyscontrol 3.5.11.10    all          V3.5.11.10, Do 10. Aug 12:28:26 CEST 2017
I recognize following and maybe that is a problem. In your instruction you said:
Quote:
5. change the runtime application directory to /media
sudo nano /etc/init.d/codesyscontrol
see screenshot
and change the location of PlcConfigFile
export PlcConfigFile=/media/CODESYSControl.cfg
and
cd /media/
In the screenshot i put my /etc/init.d/codesyscontrol.
I changed/added the yellow lines. The script is slightly diffrent then yours (see orange rectangle).
And i see that WORKDIR still pointing to /var/opt/codesys which is a unionfs (/var_org and /var_rw). So writing an boot image for example will not be stored remanent on the sd card (stored to /var_rw/opt/codesys which is a ramfs)?!?!
You said:
Quote:
2. all applications files are redirected to /media (Usb stick)
you should see Application.app, Application.crc visu directory etc on the USB Stick /media
and thats not the case. Maybe soming in the init.d script has changed which i have to pay attention on?!
PostPosted: Fri Nov 10, 2017 5:45 am
you mean everything works now (your license - missing license file) is solved?
I think the missing part is now:
Since 3.5SP11 the /etc/CODESYSControl.cfg is splittet in an fix part
CODESYSControl.cfg and Userpart CODESYSControl_User.cfg ... so if you do an download CODESYS add in CODESYSControl_User.cfg
the name of the Booproject for example.
[CmpSettings]
FileReference.0=SysFileMap.cfg, SysFileMap
FileReference.1=/etc/CODESYSControl_User.cfg
Maybe you addapt this already.
'and thats not the case. Maybe soming in the init.d script has changed which i have to pay attention on?!'
Could you please check if on your /media/PlcLogic Directory after downloading the application you see Application/Application.app and Application.crc?
PostPosted: Fri Nov 10, 2017 9:38 am
no, license still dont work! :cry: :cry: :cry:
1.) I changed the WORKDIR variable in the init.d script to /media/var/opt/codesys. Then i created the directorys and copied all files from /var/opt/codesys to it.
2.) I copied the file /etc/CODESYSControl_User.cfg to /media/CODESYSControl_User.cfg
3.) I changed the path /etc/CODESYSControl_User.cfg to /media/CODESYSControl_User.cfg in the configuration file /media/CODESYSControl.cfg
After reboot CODESYS starts normally, but still with the licence issue. Downloading an application successfully creates the directoy /media/var/opt/codesys/PlcLogic/Application and the files "Application.app and Application.crc".
As expected, in the directoy /var/opt/codesys/PlcLogic nothing is created.
After 2nd reboot i can go online and the application is running!
So "only" the license issue is still a problem... :cry:
PostPosted: Fri Nov 10, 2017 5:17 pm
you mean only the fieldbus licenses are the problem or do you mean the plc license (2h Limitation)
ist still not working?
PostPosted: Mon Nov 13, 2017 7:26 am
Only the Profinet (and OPC-UA, which i dont use).... The Raspy was running through the weekend and i just logged in without problems... These are the warning and errors from the log (screenshot):
EDIT:
2nd screenshot with information entries... (note the "runtime licensed" entry at line 5...)
P.S.: The timestamps are not correct, because the clock of the Pi are not set correctly (no RTC, no internet connection)...
PostPosted: Mon Nov 13, 2017 7:29 am
license file 3S.dat is still not accessible...
did you move/copy it from /etc/ to your new runtime location?
PostPosted: Mon Nov 13, 2017 7:43 am
Yes!
My new location is /media (mounted to the rw-partition):
:/media# ls -la
total 56
drwxrwxrwx  5 root root  4096 Oct 29  2017 .
drwxr-xr-x 25 root root  4096 Oct 26 08:53 ..
-rw-r--r--  1 root root   158 Jan 19  2017 3S.dat
-rw-------  1 root root    47 Sep  7 17:06 .bash_history
-rw-r--r--  1 root root   570 Sep  7 17:06 .bashrc
-rw-r--r--  1 root root   760 Oct 29  2017 CODESYSControl.cfg
-rw-r--r--  1 root root   242 Oct 26 08:57 CODESYSControl_User.cfg
drwx------  2 root root 16384 Sep  7 16:26 lost+found
drwxr-xr-x  2 root root  4096 Sep  7 17:06 .nano
drwxr-xr-x  3 root root  4096 Oct 26  2017 opt
-rw-r--r--  1 root root   148 Sep  7 17:06 .profile
I also tried both CODESYSControl.cfg:
:/media# cat CODESYSControl.cfg
[SysFile]
PlcLogicPrefix=1
and
[SysFile]
FilePath.1=/etc/,
PlcLogicPrefix=1
License dont work either... :cry:
PostPosted: Mon Nov 13, 2017 9:51 am
this should work if the 3S.dat is in /etc
[SysFile]
PlcLogicPrefix=1
PostPosted: Tue Nov 14, 2017 7:30 am
Finally it woks! Thank you!
But then your instructions are wrong Mr. Schwelliger?!
You wrote:
[SysFile]
I moved that files! Thats the reason because 3S.dat was not in /etc/ anymore...
Also i did not understand why changing the CODESYSControl.cfg (see below) not worked?!
[SysFile]
FilePath.1=/etc/,
PlcLogicPrefix=1
Anyhow, thank you for your support!
Regards,
adv
PostPosted: Fri Jun 22, 2018 7:57 am
Hi all,
ist this procedure still working with actual versions of codesys / Raspbian?
I am experiencing a defective linux installation after power off, and would
like to make the system read-only too. I am not, however, very familiar with
linux systems.
PostPosted: Wed Jul 04, 2018 11:24 am
Also would like to see a final instruction for Raspberry to make it read only for all cases, or better include such option in Codesys Runtime for PI directly.
PostPosted: Wed Nov 13, 2019 4:39 pm
Dear Mr. Schwellinger
Is there an instruction from start to finish available?
Would be very interested since i want to use the RPi the same way with Codesys.
Thank you very much.
Andreas Kleiner
