It is currently Tue Sep 17, 2019 10:27 pm
 Post subject: I2C baud rate
PostPosted: Wed Aug 13, 2014 4:36 pm
How can I change I2C baud rate permanently?
Default is 400kHz.
I tried:
sudo modprobe i2c_bcm2708 baudrate=100000
sudo bash -c "echo options i2c_bcm2708 baudrate=100000 > /etc/modprobe.d/i2c.conf"
But this doesn't work. After reboot, baud rate is set to 400kHz again.
Thank you.
Zdenko.
 Post subject: Re: I2C baud rate
PostPosted: Wed Aug 13, 2014 6:45 pm
Hi Zdenko,
you need to change this in:
/etc/init.d/codesyscontrol
snippet:
        make_mknod
        killall codesyscontrol.bin > /dev/null;
        export PlcConfigFile=/etc/CODESYSControl.cfg
        echo bcm2708_i2c.0 > /sys/bus/platform/drivers/bcm2708_i2c/unbind
        echo 400000 > /sys/module/i2c_bcm2708/parameters/baudrate
        echo bcm2708_i2c.0 > /sys/bus/platform/drivers/bcm2708_i2c/bind
PostPosted: Thu Aug 14, 2014 6:39 am
Thank you Edwin! It works :D .
BR,
Zdenko.
PostPosted: Mon Sep 29, 2014 10:14 pm
Hello
I'm trying to change the i2c baud rate to 100kHz following the example above. I have copied the code in to the "codesyscontrol" file but when restarting the pi, codesys does not work.
Is this how the change was intended? see attached picture.
Thank
PostPosted: Fri Nov 07, 2014 10:15 am
it looks ok.
You don't have to copy anything.
Just change parameter in /etc/init.d/codesyscontrol:
to:
echo 100000 > /sys/module/i2c_bcm2708/parameters/baudrate
and save file, then do reboot.
It should work.
Best regards,
Zdenko.
