It is currently Sun May 19, 2019 7:33 am
Post new topic  Reply to topic  [ 49 posts ]  Go to page Previous 1 2 3 4 Next
PostPosted: Wed Nov 19, 2014 6:17 am
this 'manual retain save issue' will be solved with 3.5SP6,
there is a workaround available:
Execute a 'sync' by
Quote:
Sys ExecuteCommand
after saving the retains manually.
This lead to a file flush.. retains are saved immediately.
This will be not needed then with 3.5SP6 release.
PostPosted: Mon Nov 24, 2014 11:06 pm
can you help me my code don't work:
IF Save THEN
   (* First delete the retain file.
      This is necessary, because the function AppStoreRetainsInFile appends the data at the end of the file. *)
   fbDelete(xExecute:=TRUE, sFileName:=sFileName);
   IF fbDelete.xDone OR (fbDelete.xError AND fbDelete.eError = File.Error.NOT_EXIST) THEN
      (* Attention: It takes at least one cycle until xDone is TRUE *)
      fbDelete(xExecute:=FALSE);
      Save := FALSE;
      (* Now, it's the time to save the retains. *)
      pApp := AppGetCurrent(pResult:=ADR(Result));
      IF pApp <> 0 THEN
         (* Store the variables in a file*)
         Result := AppStoreRetainsInFile(pApp,sFileName);
         _(pszCommand:='sync');
(* Restore the Retain Variables from the file.
   For storing and restoring, the same pointer to application (pApp) must be used.*)
IF Restore THEN
   Result := AppRestoreRetainsFromFile(pApp, sFileName);
   Restore := FALSE;
I can restore the retain, after a power fail.
PostPosted: Wed Nov 26, 2014 11:12 am
It is working in my case:
PROGRAM AppRetain
   fbDelete            : FILE.Delete; (* Function block to delete the file *)
    (* The retain file <application-name>.ret is placed in the directory of the bootproject *)
   sFileName           : STRING := 'App10.ret';
   pApp            : POINTER TO APPLICATION;
   Result              : RTS_IEC_RESULT; (* Result code *)
   Result1             : RTS_IEC_RESULT; (* Result code *)
   xInit            : BOOL;
IF NOT xInit THEN
   xInit := TRUE;
IF xSavePers THEN
      xSavePers := FALSE;
      IF pApp <> 0 THEN
         SysProcess._('sync',ADR(Result1));
IF bRestore THEN
   PersVarsChk := PersVars;
   bRestore := FALSE;
And you should add "sync" command in CODESYSControl.cfg, like described here:
viewtopic.php?f=21&t=5714
Best regards,
Zdenko.
PostPosted: Thu Nov 27, 2014 3:17 pm
Hi thanks...but after this stop the Raspi...wen i will restore the RETAIN
PostPosted: Fri Nov 28, 2014 9:44 am
I configured xSavePers and bRestore control bits as Global variables, so I can save and restore Retain variables from the application.
Restore is made in the INIT phase and Save is done after Retain variables value change.
Best regards,
Zdenko.
PostPosted: Fri Dec 12, 2014 1:44 pm
My small code for autosave retain on change with time filter (no raspberry!, another platform). As is.
+ CmpChecksum.lib
PROGRAM RetainManager
VAR_INPUT
   RetainFilePathName : STRING := '/tmp/extend/pccard/SD_MMC0_1/Retain';
   SaveFilterTime : TIME := T#5S;
   ForceSave : BOOL;
   Init: BOOL;
   pRetainFilePathName : POINTER TO STRING;
   pCurrentApp : POINTER TO APPLICATION;
   RetainAreaSize: __XWORD;
   pRetainArea: POINTER TO BYTE;
   dwCRCSave: DWORD;
   dwCRC: DWORD;
   TOF1 : TOF := (PT := SaveFilterTime);
   R_TRIG1: R_TRIG;
VAR_OUTPUT
   RTSIECResult : RTS_IEC_RESULT;
   AttemptSaveCounter: INT;
IF NOT Init THEN
   pCurrentApp := AppGetCurrent(ADR(RTSIECResult));
   IF RTSIECResult<>0 THEN RETURN; END_IF
   RetainAreaSize := AppGetAreaSize(pApp:= pCurrentApp, uiType:= DA_RETAIN, pResult:= ADR(RTSIECResult));
   pRetainArea := AppGetAreaAddress(pApp:= pCurrentApp, uiType:= DA_RETAIN, pResult:= ADR(RTSIECResult));
   IF LEN(RetainFilePathName) <> 0 THEN
      pRetainFilePathName := ADR(RetainFilePathName);
   ELSE
      pRetainFilePathName := ADR(pCurrentApp^.szName);
   RTSIECResult := AppRestoreRetainsFromFile(pCurrentApp, pRetainFilePathName^);
   CASE RTSIECResult OF
      0: // #define ERR_OK 0x0000
      16#1E: // #define ERR_SIGNATURE_MISMATCH 0x001E   /* Signature mismatch of an api function */
      16#32: // #define ERR_FILE_ERROR 0x0032   /* File error. e.g. cannot open a file for writing because it could be write protected */
   ELSE RETURN;
   END_CASE
   dwCRCSave := CRC32Finish(ulCRC:= CRC32Update(ulCRC:= CRC32Init(), pData:= pRetainArea, ulSize:= RetainAreaSize));
   Init := TRUE;
R_TRIG1(CLK := ForceSave);
dwCRC := CRC32Finish(ulCRC:= CRC32Update(ulCRC:= CRC32Init(), pData:= pRetainArea, ulSize:= RetainAreaSize));
IF dwCRC <> dwCRCSave OR R_TRIG1.Q THEN
   IF NOT TOF1.Q OR R_TRIG1.Q THEN
      RTSIECResult := AppStoreRetainsInFile(pCurrentApp, pRetainFilePathName^); // записасать в файл
      IF RTSIECResult = 0 THEN
         dwCRCSave := dwCRC;
      AttemptSaveCounter := AttemptSaveCounter + 1;
      TOF1(IN := TRUE);
IF TOF1.Q THEN
   TOF1(IN := FALSE);
PostPosted: Fri Nov 20, 2015 8:13 pm
Hello Edwin.
What does it mean?
I tried retains in 3.5sp7 and it still doesn't work.
PostPosted: Sat Nov 21, 2015 12:07 pm
usually nothing is needed except an UPS... no additional code to execute.
PostPosted: Sat Nov 21, 2015 12:33 pm
So the problem with manual saving retains to sd card isn't solved?
And the only way to have retains saved without additional code is unterruptable power supply?
PostPosted: Thu Dec 24, 2015 9:02 am
Hi everyone! Has anyone used 24C32(64) EEPROM chip to saving retain variables? Is it possible? I have this part: http://www.ebay.com/itm/400503978923
PostPosted: Wed Apr 13, 2016 11:08 am
Execute a 'sync' by
Quote:
Sys ExecuteCommand
Hello. I tried
Sys*Process*Execute*Command*('sudo sync', ADR(cmdResult));
but it doesn't save retains.
Sys*Process*Execute*Command*('sudo reboot -h now', ADR(cmdResult));
Reboot do the job.
Is there a command to save retains without rebooting?
PostPosted: Sat Jun 18, 2016 1:21 pm
Hello! You can learn how to turn off the raspberries to remain variable retain? Linux any team for this need. Thank you!
PostPosted: Sat Jan 07, 2017 1:30 pm
Im also looking ;-) I tried "sudo sync" with no sucess
PostPosted: Sat Jan 07, 2017 9:45 pm
Is there persistent variables on codesys 3?
Sent from my SM-N9005 using Tapatalk
PostPosted: Sun Jan 08, 2017 6:44 am
in general there are retains, but you need a graceful shutdown under Linux Debian.
(no Switch off the power supply withour shutdown)
-> so UPS (uninterrupted power supply ) is mandatory to have retain variables.
