It is currently Thu Aug 22, 2019 5:11 pm
Post new topic  Reply to topic  [ 31 posts ]  Go to page Previous 1 2 3 Next
PostPosted: Tue Apr 22, 2014 6:40 am
i've tried to reproduce that...for me the correct fb occure after insert it with input assistent.
But anyway if you have steps to repeat to reprocude it please let me know.
PostPosted: Tue Apr 22, 2014 1:22 pm
Thank you Edwin.
Enclosed I am sending the project. Maybe you can try the same. When I am adding TCP Modbus server function block in MB_FBD, inserted block is not right.
Best regards,
Zdenko.
PostPosted: Sat Apr 26, 2014 5:32 am
on 3.5SP5 Release (July 2014) there is an solution for this issue,
because we recommend to have all in the configuration it should not be needed to use modbus fb's and call them
manually. (Sure this will be always possible but the easy way is to have everything called implicit by the system)
Holding Registers (Slave %I) can be configured to overlay Input Registers (Slave %Q).
This way they can be made updateable by the Slave's application code.
See Screenshot.
PostPosted: Sat Apr 26, 2014 8:11 am
this will be great. Thank you.
Best regards,
Zdenko.
PostPosted: Sat Apr 26, 2014 2:48 pm
Edwin Schwellinger wrote:
See Screenshot.
That is great news. Keep up the good work!
nOrM
nOrM = Norman Dziedzic Jr.
PostPosted: Thu May 01, 2014 4:15 pm
Hi All,
Is it possible to have a Modbus TCP server with the same port number per each slave ID and a unique I/O mapping for each of the slaves ? I'm not a very experienced Codesys user, just wondering whether there is a possibility to amend a TCP message processing somewhere in Codesys, which could allow me to point specific slave ID's to specific data maps ?
At the moment, if we have a one ModbusTCP_Slave _Device added to the devices structure it allows to have (simulate) all 255 slaves on the same port (as I understand this functionality comes by default). Each slave has the same I/O mapping. Now, under "ModbusTCP --> Configuration Parameters" there is an option which should allow to apply a Unit ID, tried to use it expecting to have just one slave active, but looks like it makes no difference at all - am I thinking correctly about the usage of this option ?.
Besides, tried to add two ModbusTCP_Slace_Devices with different port number and only in this way I did managed to get different I/O mapping for slaves.
PostPosted: Wed Aug 06, 2014 2:09 pm
Hi all,
I like new Modbus functions support in 3.5SP5 (coils and discrete inputs).
@Edwin:
I like to change holding registers with RPi application. I made a configuration with overlay input and holding registers like you suggest. But unforunately it doesn’t work for me. Can you please suggest how to configure this to make it work.
Thank you.
Zdenko.
PostPosted: Thu Aug 07, 2014 6:20 pm
Hi Zdenko,
please send me your project.
PostPosted: Sun Aug 10, 2014 6:00 am
Hi Zdenko,
see attached example, this should show how it works, Pi is ModbusMaser and Modbus Slave at the same time (only for me to test purpose),
in case you use this with you Modbus Master which is running on you windows machine, please remove the Modbus Master from this project example.
PostPosted: Mon Aug 11, 2014 8:45 am
Thank you very much Edwin,
I understand the solution. It can be done. I tested it and works ok. But I must say that this is more like a work-around. It is not so easy to define all needed helping variables and program functionality if we have bigger project with a lot of holding registers.
I think it is easiest to use MB server function block from Modbus lib. In this case this functionality works ok. But unfortunately there are no coils and discrete inputs integrated.
It will be the best if you integrate this functionality directly in Modbus driver. It is normally used in industrial devices on the market. Do you have a plan to integrate this in the next Codesys release?
Best regards,
Zdenko.
PostPosted: Thu Jan 22, 2015 2:32 pm
Any updates on this?
/U
PostPosted: Fri Jun 16, 2017 12:28 am
Hi Zdenko,
Hey Edwin,
Can you explain what's this part is doing? I can't understand what's it doing. Thank you
PostPosted: Thu Jun 13, 2019 2:43 pm
Is there any update?
I want to share Holding & Input Registers in the same way WAGO does in Codesys V2.3 (ADR 3000hex = %MW0).
Thanks!
PostPosted: Sun Aug 11, 2019 3:19 pm
The WAGO e!COCKPIT Modbus TCP library works well, in that you can locate the holding register data array at %MW0, and then locate your global variables overlapping. Then your variables work essentially like C2.3 %MW R/W modbus variables. Tip: If you declare the array starting at a number, that is used as the offset. For example Holding_Data AT %MW0 : ARRAY[100..200] OF WORD; this would be MB4x100 - 4x200, which is very clever.
FYI: This overlapping trick also works with the C3.5 modbus slave library, however when the master is stopped all variables are set to 0 / FALSE! I had to add extra array that I "save" and "load" when the modbus slave FB client count goes to zero. Not very elegant, but works. Also I did not see any way to offset the MB address, it always starts at 4x0.
I tried the built in modbus slave server but the check box for overlapping Input and Holding did not work for me unfortunately. I was using 3.5.14.10 so maybe its been fixed since then. This would be better than using libraries, however the way WAGO implemented this in C2.3 was the best in my opinion and was loved by many. I don't like using %IW and %QW because then the HMI has to retain all parameter values, and the PLC has no means of changing those variable values which is very limiting. Of, you have to implement complicated logic to look at two variables, ugh, no thanks!
PostPosted: Thu Aug 15, 2019 6:03 pm
Hi everyone,
how can I insert the modbus server block in the project?
Can you tell me how I can insert more registers both in writing and in reading because in the menu 'modbus tcp slave devide iec objects I have only 10 registers and I don't know how to add them.
Thank you all for your answers.
