would propose to use attached example.
Either you generate single bits (in my example xIn0,xIn1) in the mapping or you map a byte and access then later with bytename.0 to bytename.7 (byOut)
the single bit's in the Byte.
Can I make programs in the IEC 1131 language LD when using PiFace as I/O-card?
How to address the different input/output pin on the PiFace?
Regards / Anders
Hi Anders,
PiFaceIoDrv_LD.project [151.49 KiB]
