It is currently Wed Feb 26, 2020 5:02 pm
Post new topic  Reply to topic  [ 98 posts ]  Go to page Previous 13 4 5 6 7 Next
PostPosted: Thu Apr 20, 2017 1:08 pm
HTejada wrote:
ekmekci wrote:
Dear All,
This topic was so helpfull for me about getting data from usb via codesys.
I used, Edwin's example it works well. I can read data from my usb GPS receiver.
But, i wonder what if i have 2 usb device at the same time.
How we can control both of them at the same time ? It is possible to do it?
For example;
For one usb device we can use
FirstSerialLine(
slMode:= SL_READWRITE,
udiPort:= 1,
udiBaudrate:= 4800,
paParity:= COM.PARITY.NONE,
sbStopBits:= COM.STOPBIT.ONESTOPBIT,
udiByteSize := 8);
what we need to do for 2 usb device at the same time.
Thank you for your help.
if 2 usb are the same manufacture, you can change udiport:=2 for second device. You can create news string i/o for the second device.
Lucky!
Hector.
Thank you for your help. But what if i use 2 usb devices which different manufacture ?
What i need to do.
Also, what is the mean "same manufacture" ? Could you please give example ?
PostPosted: Thu Apr 20, 2017 5:57 pm
set symbolic links in Linux
Example:
/dev/ttyUSB0 -> /dev/USBCDS0
/dev/ttyAMA0 -> /dev/USBCDS1
and then in /etc/CODESYSControl.cfg only this line will be needed:
[SysCom]
Linux.Devicefile=/dev/USBCDS
PostPosted: Fri Apr 21, 2017 12:28 pm
Edwin Schwellinger wrote:
Example:
[SysCom]
Thank you Edwin,
I will try and i will let you know,
PostPosted: Tue Apr 25, 2017 5:33 am
Example:
[SysCom]
Dear Edwin,
I did what you said.
Everything works perfect now.
But i have one question about serial com structure.
For example, i have GPS receiver. When i power up the receiver, gps datas comes regularly every one second.
I wonder, it is possible to understand there is data which coming or not.
I mean, according to your example we alwasys try to reading comport every 250ms randomly. If there is data we can get the data if there isnot data we still read comport every 250ms.
Is there any indicator which tell us data is coming or data has come.
I hope i explained well.
PostPosted: Tue May 23, 2017 3:25 pm
Changes in Raspberry Pi 3 related to using the on-board UART:
On PI3, ttyAMA0 is now connected to Bluetooth.
In latest Jessie version /dev/serial0 is the on-board UART (serial).
So, in /etc/codesys.cfg, you must add the line
Linux.Devicefile = /dev/serial
Also, it seems that sometimes the UART is disabled in Kernel.
To enable it, edit /boot/config.txt and set enable_uart=1
Finally, remember to disable the Linux console mode (the serial port is default used by Linux console)
PostPosted: Thu May 25, 2017 2:43 pm
I would like to connect the internal UART from my Raspberry over a MAX485 RS-485 Module from eb.. to an arduino so that i can send data over modbus rtu.
I have done the change in the CODESYSControl.cfg
[SysCom]
Linux.Devicefile=/dev/ttyAMA
portnum := COM.SysCom.SYS_COMPORT1;
Now i have the problem that i dont know how to connect the module to the raspberry ;-)
I tried it like on this page. LINK
Without success
I have a Modbus COM PORT in my Projekt with a green symbol.
The modbus Master is also green.
But the Modbus Slave is changing between red and orange
Maybe someone can help ;-)
Chris
PostPosted: Fri Feb 02, 2018 9:15 am
We are trying to connect a serial device via FTDI to Serial USB cable. Communication works fine with minicom but, after following all the steps to link the serial port to Codesys, nothing happens. An Error 5004 (unknown error) is showed. We are trying with the sample project SerialcomwithVisu provided in the Codesys store.
The serial port is identified as "ttyUSB0" and I've added the following lines to CODESYSControl.cfg:
[SysCom]
Linux.Devicefile=/dev/ttyUSB
Speed, parity, and all the serial parameters have been introduced correctly.
Raspberry version is 3.5.12.0, working with Cedesys 3.5 SP12 x64
We apprecciate your suggestions.
PostPosted: Sat Feb 03, 2018 12:37 pm
Check if the entry is maybe dublicated or different in CODESYSControl.cfg and CODESYSControl_User.cfg
In the /etc
PostPosted: Sat Feb 03, 2018 10:48 pm
Thanks Edwin, I've removed the entry from CODESYSControl.cfg and added it to CODESYSControl_User.cfg and now its working fine.
:mrgreen:
PostPosted: Mon Feb 19, 2018 3:46 am
Hi:
I want to connect two USB slave devices for MODBUS,
The first is a speed variator with a USB / RS485 converter
usb 1-1.5: ch341-uart converter now atachmend to tty USB0
Is Ok.
The second one would be an ARDUINO ONE
cdm-acm 1-1.3: 1.0: ttyACM0: USB ACM device.
Is a ttyUSB1 possible?
Thank you
Fernando
PostPosted: Mon Feb 19, 2018 4:10 pm
you need to google for "udev rules" or
"serial-symlinks.rules"
for CODESYS you need a configuration like:
ch341-uart converter is attachmend to ttyUSB0
and your USBAMA0 should then attached to ttyUSB1
PostPosted: Tue Aug 07, 2018 3:15 pm
Hi All,
please I need help :cry:
I want to control via Raspi (USB to Serial) a Relais Modul. It already worked at my computer (WIN7) and on the Raspi using the console. But using CodeSys I get no acces to the relais. Attached i have summarized the details.
Hoping for Feedback!
Indi
PostPosted: Fri Aug 10, 2018 10:27 am
please move your added SYScom section: [SysCom]
from /etc/CODESYSControl.cfg to /etc/CODESYSControl_User.cfg
means remove it from /etc/CODESYSControl.cfg and Change the existing in /etc/CODESYSControl_User.cfg to
[SysCom]
Linux.Devicefile=/dev/ttyACM
PostPosted: Tue Aug 14, 2018 5:47 pm
Thanks a lot. Now it works. :)
PostPosted: Thu Sep 20, 2018 6:09 pm
Hello All!
Since I'm new to Linux and Codesys, I was hoping that somebody here could help me :D
I'm using an Apalis Module, with Angstrom version of Linux, and I'm trying to use its serial port with codesys.
The Apalis Module has 4 uart ports(/dev/ttymxc0, 1 ,3 and 4) and I've tested all of them by short-circuiting Rx and Tx Pins and sending an echo command or with minicom. All those tests came out ok. But when I try to use it with Codesys, it doesn't work :(
I am using this code to open the serial port.
Basically it is the Serial Com example with SysCom Library, the only change was the serial port 4 selected and it is only the code to open it:
   bOpenCom: BOOL := TRUE;
   hCom: RTS_IEC_HANDLE := RTS_INVALID_HANDLE;
   Result: RTS_IEC_RESULT;
   csComSettings: COM_Settings;
   bWriteCom: BOOL := TRUE;
   dwWritten: UDINT;
   dwOffset: UDINT;
   str : STRING := 'abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ1234567890$R$N';
   abyWriteData: array[0..4095] of BYTE;
   i: INT;
   bReadCom: BOOL := TRUE;
   dwRead: UDINT;
   strRead: STRING;
   dwWrittenLog : ARRAY[0..49] OF DWORD;
   dwZeroWrittenCount : DWORD;
   iCurWrittenLog : INT;
IF bOpenCom THEN
   bOpenCom := FALSE;
   // Prepare test data
   FOR i:=0 TO 4095 DO
      abyWriteData[i] := str[i MOD 64];
   END_FOR
   // Open COM port 4
   hCom := SysComOpen(sPort:= SYS_COMPORT4 , pResult:= ADR(Result));
   IF hCom <> RTS_INVALID_HANDLE THEN
      // Configure the connection
      csComSettings.byParity := SYS_NOPARITY;
      csComSettings.byStopBits := SYS_ONESTOPBIT;
      csComSettings.sPort := SYS_COMPORT4;
      csComSettings.ulBaudrate := SYS_BR_9600;
      csComSettings.ulBufferSize := 0;
      csComSettings.ulTimeout := 10;
      Result := SysComSetSettings(hCom:= hCom, pSettings:= ADR(csComSettings) , _:= 0);
and here is the CODESYSControl text:
CODESYSControl.pdf
Is there any other configuration that I should do? like in the device description of the apalis module?
I hope there is enough information and that somebody knows what is the issue :D
Thanks for your time and have a nice day!
edit:
I found out that i was missing a ; in
[SysCom]
Linux.Devicefile=/dev/ttymxc4
portnum := COM.SysCom.SYS_COMPORT4;
but it still doesn't work.
now i tried removing the number from "/dev/ttymxc", and i don't get the "unknown error" anymore. it returns me a number like 0x12,0x13,0x14,... (i think it's related to some other serial port)
and any of the /dev/ttymxc0, /dev/ttymxc1, /dev/ttymxc3 or /dev/ttymxc4 seems to be opened
edit 2 (solution):
since i was able to open the serial port using these configurations
[SysCom]
I figured out what the problem was
apalis uses 4 serial ports, but its names have a gap between uart 2 and uart 3, so should the COM port number be called with this gap
uart1 -> /dev/ttymxc0 -> COM1
uart2 -> /dev/ttymxc1 -> COM2
uart3 -> /dev/ttymxc3 -> COM4
uart4 -> /dev/ttymxc4 -> COM5
so... i was opening 1 port, but instead, was testing another :evil:
Users browsing this forum: No registered users and 8 guests
